Question about Panasonic Televison & Video
Recently bought Panasonic TX-51250H REAR
Recently bought Panasonic TX-51250H REAR PROJECTION TV ONLY to find out that there is a blue arc in it and under the arc is a black arc....is this beyond repairing?or how can i fix this
thnks
premtech
  • 934 Answers
SOURCE: colour problem on rear projection tv
This might be something really simple... In a large number of DPTV310 chassis, of which this TV is, the yoke connections where put in place with black electrical tape just below the retaining rings. Job is to loosen the rings, remove the tape and push the yoke back in place and tighten down retainer.. Be careful not to throw off the tilt of the yoke. The adhesive on the tape, over time, gets hot so many time it becomes slippery and allows the yoke to fall away from it's position dulling the look of the image (or focal length) causing the problem you're describing here... It also throws off the convergence - so in attempting to converge it just looks worse. Good Luck Bill
Posted on Jun 11, 2007
Slinteriors
  • 8617 Answers
SOURCE: Akai PT5492S 54" Rear Projection TV
Your set needs to have both Convergence ICs replaced they are Both STK392-010 you can get new ICs at the following link and they provide free step by step instructions with pics so you can do the job yourself which takes about 45 minutes. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 10, 2008
  • 19 Answers
SOURCE: color spots on panasonic projection screen
The light engine may be dirty with dust, the polarizer filter burned, or the LCD elements burned.
As a last-ditch effort, the light engine can be taken apart and carefully cleaned using compressed air.
Posted on Jul 29, 2008
  • 41 Answers
SOURCE: I have a rear projection panasonic 51" tv with blue curved lines
This can be repaired by a Degaussing coil from most TV repair places. If you haven't already you should shut down the TV and wait till it cools maybe 1 hour or so and then when you turn it on there should be a degaussing circut that might clear this up for you build into the set. Its not that strong a signal and usually takes care of minor discolorations. If it doesn't have that then a shop can come and take care of it pretty fast usually.
Posted on Mar 29, 2009
Slinteriors
  • 8617 Answers
SOURCE: blue tint ghosting, seems like a convergence
yes you can get the PT47WX49 convergence repair kit at the following link listed under their Panasonic kits category. The kits contain the two Convergence ICs and the feed resistors plus a CD which has the installation instructions. www.tvrepairkits.net
Posted on Jun 25, 2009
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
Blue arc from bottom of TV screen and no amount of alignment will fix the problem
Replace the convergence Ics and check the 2.2 ohm 2watt resistors. You can get The PT53WX53 convergence repair kit from www.tvrepairworld.com the kit has the IC's and resistors and the CD with instructions for the repair.
Jul 21, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
Color patches on my panasonic lcd rear projection tv
I had about six green spots and two blue spots about the size of baseballs. Panasonic came out and fixed this for me for free!! They said they "reprogrammed an eprom". I bought the TV in Nov. of 05 and this is Jan 09. Go Panasonic!!
Aug 04, 2008 | Panasonic Televison & Video
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Open Questions:
Televison & Video Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
