Question about Casio Exilim EX-S500 Digital Camera
No Pictures Everytime i try to take pictures with the camera, they come on completly black. It's as if there's something in the way of the lens, but there's nothing on the lens, i've tried wiping it off, and cleaning it. Still nothing, any help?
  • Anonymous May 22, 2009
    same
    Problem Solver:
  • 17 Answers
It don't work shutter. You camera need repair lens unit.
Posted on May 16, 2009
Developed film pictures have black around the edges
My guess would be that whatever lens your using is causing that. The black edges are basically caused because the lens may not be fit the camera correctly, causing the camera to "see" part of the lens itself when taking a photo.
May 03, 2010 | Pentax Photography
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
Screen stays black when turned on in take picture/video mode
There is something wrong with the lens. Perhaps its obstructed by something or the lens doesn't really open @ all. Try cleaning the lens with lint free cloth if not. Follow the in-warranty repair process @ www.kodak.com/go/stepbystep the website will ask you to troubleshoot first. Just keep following the website in the end if issue persist it will give you the page that you need to fill up so that you can send your camera and repair.
Note: After filling-up the information on the page and completing it wait for an e-mail from Kodak it will give you details how to send your camera for repair. It will also contain the address and phone number of the repair centre.
Lester
Kodak technical support
Oct 04, 2009 | Kodak EasyShare C913 Digital Camera
My camera screen goes white everytime i turn on the camera
I Havee The Same Problem And Ive Been Reading Around And The Most Decent Answer I Found About What Was Wrong Was That Something Had Just Come Loose Inside So That Might Help Because Something Wiring Upo To The Screen Might Be Loose Its Worth A Shot.
Jul 26, 2009 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Black screen, black pictures
Set to auto shooting mode, take pictures, if still get black pictures, you need to repalce the lens unit. CCD or shutter defected.
Jul 08, 2009 | Olympus Stylus 720 SW Digital Camera
I have a sanyo camera 7.1 mega pink and everytime i try and take a picture my screen goes black and shuts off without the camera piece going back in! I have almost the same problem except when I take a...
In the first case, if the camera turns off by itself with lens not retracting, try fresh alkaline battery. If that does not work, then the ribbon cable from battery charger to mainboard inside the camera is probably causing the problem.
An internal contact can also cause same problem.
If instead pictures are completely black, then there are several possible reasons:
1 There is a setting problem, remove and put back batteries to fix the problem.
2 The camera curtain is stuck and it is not opening.
3 The CCD sensor is faulty, more likely the ccd sensor contacts are broken.
4 The lens assembly has an internal problem.
Apart situation 1 , in all the remaining cases the camera will need repair.
Regards.
Jun 01, 2009 | Sanyo VPC-S880 Digital Camera
My camera is taking black pictures
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Apr 16, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera
It a lens misalignment try tapping the lens gently in an opposite direction the camera dropped on and that should pop the gear back into place
May 12, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Cant take any pictures
the Shutter or some assicated components is shattered. This may be a repair situation at Nikon- but if you have had the camera for some time I suspect you will be buying another camera.
Aug 13, 2006 | Nikon CoolPix S2 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
73 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
