AC Thermostat wiring
I have carrier centeral AC (cooling and heating) with two programable Thermostate units, one upstairs. I noitced that near the AC(furnice) unit there is a board with relays on it with connectors with 4-5 cables connecting to them and one cable is going to AC unit. This board is just dangling from the wires.. Should this board be in a box or something. I notice that on the ralay board it says ''Danny Ramsey'' is this a replacable unit? or should i mount this to the wall?
  • 148 Answers
YES U SHOULD MOUNT IT
Posted on May 10, 2009
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
I have a bryant model 702b packaged unit with 5 wire thermostat wiring coming out of the unit. R Y B G and W. The thermostate in the house is 5 wire and goes to the old central unit and them has a 4 ire...
R-Red is power
Y-Yellow is cool
B-Blue is cool as well
G-Green is fan leg
W-White is usually heat Leg
If you have no indoor unit and this is a ac/gas or
electric outdoor unit try this.
R to R/Red to Red
G-G/Green to Green
Y-Y/Yellow to Yellow
W-W/White to White
-Dont Hook up Blue.
Turn power back on turn the fan to on,fan should run
Turn to Heating, heating should come on
Turn on Cooling,if cooling does not come on switch yellow with blue.
Jul 02, 2010 | Heating & Cooling
I just had new vents run in the basement and even though they are closed, it will not cool the upstairs. It is 80 degrees upstairs. What is the problem?
First when you add new vents make sure your unit is big enough to handle the extra load. If you have shut off your vents to the basement. and it does not cool you may have AC problem. Sounds like you need to get it checked. Ask for a free estimate before you commit anything. Remember if they add gas you have a leak and it should be found. Rus When your ac does not cool properly check filters float switch in unit. Breaker on outside unit. Take a thermometer and take a reading from the reurn to the closest vent you should have between 17 and 21 degrees diference across the coil. If you have electric heat or heat pump you may need have a heat sequencer stuckmkeeping part of the heat on during cool.
Jun 26, 2009 | Carrier 38CKC042 Air Conditioner
Carrier thermostat reading stuck on 50 but doesn't work
If it is Carrier tstat. Some have resets other dont. Kill power to insid unit. WAit five minutes turn back on. If it has batteries take them out. But the storm may have damaged the tstat. I had a thunderstorm damage 11 tstats in one building. You can buy a tsta at Home depot that will work and they are easy to wire. Just make sure you get the coorect tstat. If the unit is straight cool electric thats the easy one. A heat pump you need a Tsta with two stage heat one stage cool. You can pick one up for about 25 to 30 dollars. Please call back for more help be glad to assist.Rusty
Jun 13, 2009 | Heating & Cooling
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
Honeywell thermostat
make sure not turned on @ tstat to man ,also were you in the heat or cool mode when this occured .
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Ac heat carrier thermastat model no.hh01ad042
GOto the iside unit itself. and remove the door and look for a terminial strip that the thermostat wires from the thermostat connects to and write down the colors wires and the letters they're connected to and connect the same to the thermostat .... they should be... r--red=power w-white=heat y--yellow=cool g-- green=fan! See which wires/ colors they're not using and bend back! Thank-you-very-much!
Aug 31, 2008 | Heating & Cooling
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
