Question about Car Audio & Video
I have a valor dvd player in my 2004 pontiac grand am with the 8 speaker monsoon stero system built in 500 watt amp,, i have a 1000 watt amp hooked up to two 10 inch woofers,,,,when i turn the car on the amp lights up green until the music plays(the amp gets power long before the head unit folds out and loads music) when the music starts the amp green power light dims ,,the subs produce very little bass and are very crackly and distorted,,very very low bass,,i tried new amp, does the same thing,,the red protect light even dimmed on just alittle, tried new subs and same thing
  • 58 Answers
MAKE SURE UR GROUND WIRE IS TIGHT, AND MAKE SURE UR RCAS ARNT NEXT TO THE POWER WIRE.
Posted on Jun 18, 2009
I have a 2000 Oldsmobile alero and I can't get any sound out of my rear speakers good speakers and connection just can't get any sound out of them
Installing/Replacing rear speakers in a 2002 Pontiac Grand ...
? 5:11
https://www.youtube.com/watch?v=aiWwA6bXvhE
Nov 30, 2010 - Uploaded by Turbo231
Installing/Replacing rear speakers in a 2002 Pontiac Grand Prix GT DIY ... same as a 2000 grand prix ...
How to remove back speakers and install in a 98 02 ...
? 17:50
https://www.youtube.com/watch?v=pIxGeqy9QYI
Feb 26, 2014 - Uploaded by Can't Kill Me
How to remove back speakers and install in a 98 02 Oldsmobile Intrigue. Can't Kill Me ... 6x9 Rear Car ...
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
how do you replace rear speakers? - Aleromod.com
www.aleromod.com > ... > General Help > Audio, Video & Security
Feb 13, 2013 - 20 posts - ‎7 authors
I just tryed it and I have no idea how to take that plasic thing out! ... I replaced the deckspeakers on my alero as well as my friends and didn't .... remove the rear deck...next thing is that if you have monsoon sound let ... Get better aftermarket speakers and then say ehh...i wanna go back to the weak stockers. Stero Question
May 21, 2013
Monsoon and aftermarket speakers
Sep 9, 2011
Aftermarket Headunits, Wiring Harnesses
Feb 19, 2004
Installing Aftermarket Radio, 2001-2004
Nov 20, 2003
More results from www.aleromod.com
Jan 21, 2016 | Oldsmobile Cars & Trucks
How do I disconnect the amplifier on my 2005 Grand Prix; it makes continuous static noise whether the radio is on or off or whether the ignition is on or off?
Assuming it's the monsoon amplifier it's located under the rear deck about 8 inches away from the passenger rear speaker. However unplugging it will kill all the speakers. The only way to properly bypass it is to run all new wires.
You maybe able to find another factory amp at a salvage yard.
Warning: Most of the Monsoon head units have a 6V offset, making it incompatible with aftermarket amps.
Feb 28, 2015 | 2005 Pontiac Grand Prix
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
How to splice factory speaker wires on 2004 grand am with monsoon
everything depence of system you putting in your car if u have no amplifire you connecting the speakers to radio as they marked i you putting one in, your speakers wires goes from amplifire to speakers there is no diffrent way of connection. also the diameter of your wires have to be adekwate to power u going to have in your system for optimizing the sound quality let me know if this help ya
Sep 22, 2012 | 2004 Pontiac Grand Am
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Trying to hook up speakers to Pyle Pro PD1000 stereo receiver w/built-in DVD/CD player. I believe that I have speaker wires hooked up correctly but when I play CD no sound. I can actually hearing sounds...
I went thru user manual..there is no special way of wiring speakers..
pls check carefully the speaker connections again and the "speaker selector" too..
what about "MUTE" button ? it should be "OFF" ...
and try to test it on FM radio first ..
just in case ,if you need the soft USER MANUAL pls visit the URL below..
1000 Watt AM-FM Receiver w/ Built-in DVD/MP3/USB
http://www.pyleaudio.com/sku/PD1000A/1000-Watt-AM-FM-Receiver-w-Built-in-DVDMP3USB
Jul 10, 2011 | Audio Players & Recorders
I have two sp2 speakers i am using a ipod numark dj machine connected through my 2600 watt peavey amp it keeps blowing out one speaker can you tell me why
The SP2 speakers are rated at 1000 watts PROGRAM which is around 500 watts RMS MAXIMUM. You should be using an amp capable of a maximum of 500 watts a side... Your amp is WAY too big. You will have to throttle it down. The speakers have the protection for the tweeters but NOT for the woofers. At five hundred watts RMS and 8 ohms the current is: P = I^2 * R so I^2 = 500/8 = 62.5 so MAX current is 7.9 amps. I recommend you put a 8 amp FAST BLOW fuse in the speaker leads. If the fuse blows, you have saved another speaker and you are DRIVING them too hard. For greater safety make the fuse a 7.5 amp fast blow. Also get a sound meter. The max on these speakers is 125 Db at a meter distance... and in your venue you should NOT exceed 100 Db to be safe with the OSHA regulations regarding hearing protection... I suspect you are driving the speakers too hard. One side may be getting more bass. The speakers are rated down to 55 Hz. DO NOT boost bass up as you will overheat the speakers. If you are using microphones, be careful of feedback, especially that above hearing range. If you need real low bass, then get an 18 inch subwoofer. No matter, stay within safe sound levels to avoid lawsuits and hearing loss... I know several deaf musicians...
Jul 07, 2011 | Music
2002 Grand am gt monsoon, hook up rear aftermarket speakers
You have to test them, either should work fine (as in use either pair) if that doesn't work connect one pair at a time and listen for the difference, one pair might be for factory midrange and other for tweeter.. there are two different wiring configurations...
Jan 28, 2009 | 2002 Pontiac Grand Am
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Jan 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
