Question about Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L
Table and base not level (co-planar). Extension wings higfher than base as well.
Bosch 4214L Cmpd Miter Saw. The base and rotating table are not co-planar. The table is highr than the base, more on the left than the right. The extension wings are highert than the table on both sides. Thsis causes cuts to be not square. I did not discover this initially becasue I used short pieces of scrap to calibrate the saw at initial set-up.
  • a-cut-above May 10, 2009
    Typo: it's a Bosch 4212L, not 4214L.
    thanks.
  • 2,176 Answers
Just read thru most of the user manual and they do not address this situation. Most major adjustments they list as Service Center meaning they might have to completely disassemble and find out hy this saw is not accurate, wish I had better news.
Posted on May 25, 2009
How to install router to table saw
You need to make one of the extension wings of your table saw into a router table. Meaning you need to modify (cut a rectangular or square hole into the extension wing;s surface to be able to mount the router into it. Just google "router table on a table saw" or something like that and you should see a few examples.
Aug 24, 2014 | Saws
Bosch Glide Miter Saw get stuck at 45 degree bevel to the left
Adjusting the miter angle involves two cast surfaces sliding against each other. If those surfaces have some irregularities, high spots on the two surfaces will bind against each other. You may have to disassemble the rotating table from the base and do some filing or grinding.
Dec 29, 2013 | Makita Tools 12" Compound Miter Saw -...
Want to replace table saw table
Refer this inquiry to Mastercraft.
Dec 08, 2013 | Mastercraft Saws
What is a compound miter saw?
A compound miter saw has a rotating vertical pivot allowing the cutter head & blade to be tilted (or beveled) sideways in addition to the horizontally rotating table. This allows vertical & horizontal angled cuts as well as cuts angled in both planes.
Jan 28, 2013 | Saws
My 10" Bosch miter saw
I would remove the blade and try the saw again, there is a possibility that you might have gotten a flange on incorrectly or left the spacer out.
Sep 10, 2011 | Bosch 10" Slide Miter Saw
Ryobi compound miter saw Model TS1341 To rotate the table assembly on the base to change angle of cut is very difficult. The table assembly and base are aluminum that slide or rotate against each...
you might try some silicone lubricant spray (available at auto supply) the stuff is very slippery. spary a little on the underside parts that rub on one another, try not to get any of the silicone on the top parts of your miter box as it will get on the wood that you are tyring to cut and it will leave a stain.
Mar 22, 2011 | Ryobi Saws
What is the number and letter code description mean on bosch saw blades? for instance pro 1072 sm. what does the sm stand for
The Pro 1072SM is a 10" 72 tooth blade for a Mitre saw. So the sm means "saw miter" I don't know why they reverse the words.
Likewise a Pro 1040CHB would be a 10" blade 40 Teeth and used for chipboard, hense the "CHB" at the end.
Dec 06, 2009 | Bosch Accessories Table/Miter Saws Blades
The table binds when I rotate it to change miter settings. When I cut miters(45 degree) I'm not getting straight cuts along the edge. The saw is on a plywood base mounted to a Dewalt miter saw stand. I...
Could be the wear plates under the table between it and the base. Or if it doesn't have any then the two mating surfaces are dry and rubbing causing this problem I would suggest going to Dewaltservicenet.com and typing in your model number and downloading a breakdown for the tool. To remove the table on most saws you have to remove the fence and that requires that you square everything up upon disassembly. Let me know and I will try and help further. By the way to clean the parts I use a surface conditioner with something like a scrubbing pad and then after everyting clean use a dry silicone lubricant or equivelant.
Sep 13, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Mar 15, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Saw har to rotate for bevel cuts
There are tabs on the glide rings and yes there are only 3, you should find indentations in the base for the rings, I would clean them off thoroughly and use a lithium grease on them (film coat) check the table for signs that the rings have dug into it and if so smooth out before reassembling. If tabs are broke off the glide rings you would need to replace them. Let me know if you need more help
Jan 28, 2009 | Bosch 12" Compound Miter Saw 3912
Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L Logo
319 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
