Question about Dell Studio 17 Laptop
Cell phone modem issues
I have a new Dell cpu that does not seem to have a modem. This is ok because I am using an Alltel cell phone tethered to the laptop as my modem, however I am having trouble loading the alltel software. After I downloaded the software the wizard comes up to walk me through the setup, then it gets to a point and says your computer will now use the modem wizard to install the phone as a modem. Nothing ever happens after I hit next. It seems to be looking for a wizard that doesnt exist on my cpu. what can I do to get the alltel software loaded?
  • Jubert Ledesma
    Jubert Ledesma May 11, 2010
    what is your operating system? xp or vista?
Tip
Use ANdroid phones as Modems when using laptop or desktop(pc).
The process of converting android phones to modem is called Tethering.
Before looking for and purchasing a suitable app, you will need a few things:
Android phone
Android phone drivers for your laptop or PC's operating system
USB cable
You should also be aware that using your mobile as a modem will impact on your data plan, so make sure that tethering your phone won't result in a huge bill from your network. Note also that some networks block tethering, which is why you might need to root your Android.
The first thing you need to do is find a suitable app. Several are available from the Market each with different requirements. Some must be paid for, whereas the free ones will usually require root access.
Four popular Android tethering apps are:
PDANet - costs $10 and doesn't require root access; also requires a desktop app.
EasyTether -this app is also $10 and doesn't require a rooted phone.
Tethering Widget - a free tethering app that requires your Android to be rooted.
Tethering - a free app that doesn't require rooting.
(I personally prefer tethering bcause its free)
Once downloaded and installed, these apps can then be tethered with a USB cable to use your Android cell as a modem for your computer.
HOW TO
Now that you have chosen and installed a suitable app to use your Android phone as a wireless modem, you can take advantage of the functionality it delivers. Once your phone is connected to your PC or laptop you should find that with the app installed and running, and the correct drivers installed on your PC, the computer will detect your phone as a modem and let you access the Internet with it.
There are differences in the various apps at this stage (for instance PDANet employs a client app on your PC) so you will need to check the instructions for the one you choose. The general rule is that with mobile internet active on your phone, your Android connected by USB to your computer and the application running, your PC will now be able to use the phone as a new network connection!
eNJoy !!
on Feb 06, 2011 | Google Android
I dont know how to connect internet using my mobile phone se x8 as modem
You can download an app called PDAnet or Easytether on to your phone and use this to connect with your laptop and have the phone' as a modem.
Go to android market and search PdaNet and install it in phone. Then in pc download from following link http://pdanet.en.softonic.com/ and install it in pc.
http://www.appbrain.com/app/tethering/com.guardam.Tethering
Thanks,
Jul 27, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Ive read several different instructions on how to make the cell a modum for access to the internet over a lap top/ net book. i purchased and downloaded a driver for a blue tooth dongle as my netbook did...
Have you installed the Sony Ericsson PC Suite for XPERIA? if not, you to install it on your netbook. This will allow you to make internet connection with your netbook.
Feb 18, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Can i used bluethooth to pair my samsung champ to my pc an used it as a modem to get connect to internet?
This phone does not have WLAN so it doesn't have a built in modem. As such, this phone will not 'tether' a PC to the Internet.
Note: When you do find a phone that has a modem to tether with, consider using a USB cord to connect the phone to your PC instead of Bluetooth. You'll be able to view Internet pages much a faster.
Jan 28, 2011 | Samsung Cell Phones
I'm trying to use my KC910 as USB tethered modem
I hope once you are connected you will pay the bills or maybe your employer will foot the bill---lucky man
May 11, 2010 | LG KC910 Renoir Cell Phone
Can I download modem on dell laptop
Most of the time on laptops if there is no phone input for a modem you cannot just plug in and dial up. The process i use at home for my pc is dialing through my cell phone. If your carrier will allow you to tether your phone without extra charges check your phone manufacturers website for modem software. You then just connect your phone through a usb cable and set a internet connection matching your carriers instructions. Another solution is dificult without networking knowledge but you can set up a home pc with a wireless antennae as a ad-hoc server through internet connection sharing and then allow your laptop to connect through the "server" pc.
Apr 07, 2010 | Dell Computers & Internet
Can I use the Samsung alias 2 is an Internet modem
    Using Alias 2 as Modem
  1. The Alias 2 can, in fact, be used as an external modem to connect your computer to the Internet. To do this, the phone must plug into the computer via USB. The USB data cable specific for the phone is purchased separately and can be found at most any cellular phone store and eBay. Because USB is a powered connection, anytime the phone is plugged into the computer for use as a modem, it will also remain charging, so you don't have to worry about battery life while online.
    In addition to the cable, you must subscribe to a specific service through your cellular provider in order to use the Alias 2 as a modem. This plan will be a "tethering" plan and will have a separate charge each month to use it, similar to a cell phone's data plan. By signing up for this feature, your phone will be able to dial into the data network and utilize the Internet connection as a modem, allowing any connected computer to surf the Internet. Once this feature has been activated on your account the option will become available on the phone itself to enable tethering.
    At this point, you should be able to turn on tethering, connect the phone to your computer via USB cable and select the phone on your computer as an Internet connection source.
    It is important to note, however, that the Alias 2 uses a different and slightly older system on the 3G cellular network. Because of this, using the phone as an external modem will produce a slightly slower Internet connection than a traditional modem or even a newer phone would. However, as a backup solution for Internet connectivity or a travel solution, the Alias 2 will work just fine as a modem for your computer or laptop.
Apr 01, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
The LG KC910 has the Android operating system. The Android OS does not include the tethering application required for using your phone as a modem.
You will need to download 'PdaNet for Android' to tether your LG KC910 to your PC.
You can download the program from this link - it's free to try but you'll have to purchase it to be able to access secure websites.
http://www.junefabrics.com/android/index.php
Mar 19, 2010 | LG KC910 Renoir Cell Phone
Use iphone for internet on my dell xp laptop
you need special software and probably jailbreaking it
Aug 29, 2008 | Apple iPhone Smartphone
Dell Studio 17 Laptop Logo
50 people viewed this question
Alun Cox
