Question about Dryers
Dryer won't turn on
Kenmore dryer, 18 years old won't turn on all knobs ok plugged in breaker on door closed what else can I do or check
    Scholar:
  • 43 Answers
Using a resistance meter, check the resistance of the motor that turns the dryer. If it short circuit (0 ohms) or open circuit (50ohms or greater) then you'll need a new motor.
There may also be a open circuit to the motor than inhibits it from functioning correctly.
An appliance serviceperson should be able to troubleshoot the motor and any other circuit faults. Perhaps a new (or slightly used) dryer is the cheapest solution.
Posted on May 10, 2009
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Started then stop and wont come back on. circuit breakers checked, all wiring checked, door closed. light on inside on, could the start stop switch be defective?? dryer is about 10 years old. DRYER...
yes could be start /stop microswitch...firstly make sure fuse ok in plug also feed ok lastly ensure post to operate door switch has not broken off........hope this lot helps.....
Jan 14, 2011 | Dryers
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
Kenmore dryer does not turon on
CHECK THE FOLLOWING---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
May 31, 2009 | Kenmore Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
My dryer does not work at all
Check the circuit breaker that feeds the dryer, even if it looks OK, turn it off and back on and check the dryer again.
Let me know what you find
clarkco
Feb 16, 2009 | Kenmore Dryers
Kenmore 80 series dryer won't start
Look for a bad thermal fus0526080941.jpge pix below.Straight wire to test it.Replace if the dryer turns on. 2nd. Test the door switch.
Please rate This !
Jul 09, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
