Question about John Deere Garden
Differencial transmission oil and how to check
To check trans/diff oil, depending on how old the unit is, a good many of those type are sealed units and you cannot check or add oil to them. Again this depends on the year and model. Check with a John Deere dealer and they'll be able to tell you for sure. Matt
Posted on May 11, 2009
LSpecifications on how to rebuild/repair landcruiser rear differencial
you must first afereseis the brake system after the two axes moves right and left (for releases the differencial). Take out the screws perimeter from the differencial and take off .
began to assemble in reverse.
Sep 28, 2014 | 1971 Toyota Landcruiser
Cant find fluid level check on rerend
The level should be at the top of the hole in the oil plug,if it is full,and the plug is removed,the fluid should run out.If it does not,fill it until the fluid runs out.
Sep 11, 2010 | 1980 Chevrolet Corvette
My 2005 sliverado is whinning on take off is this the transmission or the torque convertor
Have check you tranfer case, front differencial and the rear you could be low on oil
Aug 05, 2010 | 2005 Chevrolet Silverado
I don't know the distance intervals to change timing belt and Differencial system oil.
Timing belt at 100000km or 60000miles , Diff oil in a car about the same, in a 4WD , more often especially if using in water or very dusty conditions.
If uncertain, change them sooner, Belts and oil are much cheaper than bearings and rebuilt engines!
Hope this helps Marshall
May 09, 2010 | Cars & Trucks
1999 VW Cabrio Speedometer Not Working
it is possible,if it's not a speedo itself.
if you would have VAG COM scaner , you could check instrument cluster and determine if you have bad speedo or speed sensor.
Speed sensor on the transmission , should be around differencial.
May 04, 2010 | 1999 Volkswagen Cabrio
Can you change differencial fluid or does the shop have to
NO you can do it .It is easy to do. Remove cover slowly and let oil drain out. Leave 2 bolts loosely on and pry off cover with screw driver. Oil will flow out very fast. Clean cover and diff. where they meet, put on high temp. gasket sealer on theses surfaces and put back. Then fill with correct gear oil till it flows out of hole.
Jan 22, 2010 | 2004 Ford F150
I need type of fluid for 1992 chevy c2500 manual trans.
you don't need a fluid actually, you need a gear oil. Gear oil is for maual transission and also for the differencials. Go to any auto parts store and ask or just buy gear oil, that container should be included with the pump, so that more easier for you to fill it. Ok. f
Nov 21, 2009 | 1992 Chevrolet C2500
Garden Logo
195 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
