Question about Sony Dual Shock 3 Controller for PlayStation 3
How to fix the ps3 wirelees connection( not the internet)
Every time i try to get my ps3 controller to turn on in wireless mopde it wont work. I always have to use the usb cable just for it to work. I think the problem is the wireless thing because also when i try to pair up the playstation3 official bluetooth device with it, the thing takes forever to scann and it still wont scann because it says there was an error with regitering the blurtooth headset.
  • 3 Answers
SOURCE: PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Posted on Jul 09, 2008
SOURCE: How do I sync Big ben wireless controller to ps3?
hi, i had this problem also. u have to plug in the usb receiver (looks like a usb storage that you would use for pc) into the front of pc. make sure you have batteries in controller turn it on and press home. red light will flash on usb receiver until controller is paired with it. hope this helps
Posted on Jan 09, 2009
  • 4 Answers
SOURCE: the device wont pair with my phone
  1. Make sure headset is off.
  2. Press and hold the answer button until the light flashes green and red.
  3. If it only flashes green, press and hold both volume buttons until the light flashes red and green.
  4. It is now ready to pair: follow the instructions in the bluetooth menu of your phone. When asked for the passcode enter 0000.
  5. All done.
Posted on Feb 23, 2009
Big Hev
  • 64 Answers
SOURCE: My controller will not connect on my ps3.
Sounds like the controller knows it belongs to the other PS3. It has already "paired" with one console, so that's why you're having a hard time trying to get it to pair with console #2, comprende?
Make sure console #1 is a "hard off", like switched in the back. Now flip your controller over & put a pencil or pen tip in the reset hole. ( Just to the right of the center screw hole.) NOW connect said controller with the USB to console #2. Hold the PS button for two seconds. All 4 lights will flash 5 times, then the 1 light should stay on, Boo-ya! You're PAIRED!
Posted on May 30, 2009
  • 3 Answers
SOURCE: ps3 controller
Turn your ps3 on and plug in your controller with the usb cable provided with the ps3 and then press the ps button while it is plugged in and it will connect. Then unplug the controller and it should wirelessly connect.
Posted on Jun 20, 2009
My internet cant seem to work i've tried to witch my IP adress ... any ways i have a mac router do that have something to do with my internet not working????? please help!!
ok number 1 are you using wired or wireless
number 2 only use WPA for the internet password not WEP because it wont connect using that
number 3 turn prozy server off
number 4 turn off the media option in internet settings 2nd from the bottem
number 5 UPnP should be turned on
and thats it after that should be fixed also wired is better but if using wireless have ps3 standing on side and nearer the inetrnet box to make it work better
Jan 13, 2011 | Sony Playstation 3 (PS3) Console
How do i conect my ps3 to the internet wirelessly through my sky netgear router
in the network setting on the PS3 select wirelees connection and it should do the rest automatilly
Mar 08, 2010 | Sony Playstation 3 (PS3) Console
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
I cant hook up my wirelees internet. it keeps saying there is a DNS error. how do i fix it
go to network settings on ps3...click on wireless...dont do anything manual....let the ps3 searh for and do everything automatic...check settings on router and access point make sure all ports are open
Nov 04, 2009 | Sony Playstation 3 (PS3) Console
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Trying to connect to a ps3. Lights flash but wont sync
plug the controller into the ps3 and then try it..... a lot of times if you unplug the ps3 it wont recognize the controller next time you turn it on this should help
Apr 14, 2009 | Sony Wireless Controller for PS3
Dns error (80710102) on my ps3. It works wirelessly fine (but weak signal causes glitches) - but when I use a wired connection it will sometimes work fine for an hour or so and then kick me off the network...
I had the same problem and tried every solution. On the linksys website for my router they said to update the firmware. I did, enabled upnp and everythings good. Just reset you ps3 internet connection, set it to auto and let it do its thing.
Apr 11, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont connect to internet
Your PS3 should have WiFi built in unless you bought he 20GB version back when it first came out, that is the only one that dosn't have WiFi. But you can still connect it the way you want. You can use any type of ethernet cable, straight through or crossover. You need to go into your network connections in the control panel, select wired and wireless connection at the same time and bridge them. That should do it if you wanna go that route but you would have to have the computer on anytime you wanted to connect your ps3 to the internet. The best bet I think would be to just use the WiFi built into the PS3
Feb 14, 2009 | Sony Playstation 3 (PS3) Console
My ps3 controller wont connect with my ps3
Brian,
If after connecting to the USB it still won't work wireless, the best thing to do is this:
1 - Connect the controller to the PS3, via USB
2 - Click the PS Button to turn on the system
3 - On the XMB screen, click the PS Button again. You'll get the options, to "Turn off the controller". Do that and then turn it on again. It will reconnect with your PS3.
Regards,
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
Connect ps3 wirelees to internet
On your PS3, do the following:
- scroll to settings
- network settings
- internet connection settings
- select wireless
Follow the on screen instructions, and use the 'easy' set up option as it is all that is required on most.
For your Router:
- Know the SSID
- Have WEP key or any security info to hand
- If you have the SSID broadcast switched off on the router, it may not appear on the PS3. If the PS3 cannot locate your network, try enabling SSID broadcast.
Hope that helps!
Nov 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Dual Shock 3 Controller for PlayStation 3 Logo
690 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
