Question about Coleman Heating & Cooling
I have a 1971 mobile home and it has a coleman gas furnace in it modle #8665D766. I can turn the thermastate up and the combustion fan comes right on but the igniter never ignites. The pilot lite is lit. The combustion fan will continue to run until I shut the thermastate off by hand
  • rabbitshay62 May 11, 2009
    I got the problem fixed
It sounds as if one of the sensors is not signaling correctly, If the combustion fan is on. What you need to due is turn things off for a minute to test your sensors. Start by looking at the emission sensors. This can be done by looking at the schematic and following the line of electrical flow to the main switch. I had this same problem on a home furnace and all I did was follow that line of flow and checked the sensors by disconnecting each to see which one showed either an open or closed circuit, when it was supposed to be just the opposite. (Usually its supposed to be open if no flame is present, so you might see a short) It was in fact the sensor in combo to the igniter fan. If you don’t have the schematic I would look to Colman. All these circuits are simple circuits and very little trouble shooting to resolve. The hardest part is finding the parts to fix it. Thus the internet and the need for a schematic if you can find one. Most heating and air-conditioning outlets wont sell you parts even if you have an engineering degree and don’t want do deal with a technicians BILL.
Posted on May 13, 2009
How do I replace filter panels on Coleman mobile home gas furnace after I have changed filters on them? They won't go back in easily
one post only,please delete copied posts,http://www.mobilehomerepair.com/mobile-home-furnace-maintenance-troubleshooting/
Oct 07, 2016 | Coleman Heating & Cooling
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Coleman wiring diagram
I can't find any manual but i found a site where the same model was installed in a 1971 mobile home. Their unit had been tampered with and is a fire hazzard.
Nov 08, 2013 | Heating & Cooling
Furnace fan will not shut off
if the fan just runs check the limits there is about three of them and a high limit some of them are Manuel rest witch means you have to press the button on them
Dec 25, 2012 | Coleman Mobile Modular Home Gas Furnace...
Coleman furnace
Is this a blend air system? If so, there is an upper & lower control board that communicate to each other, and if the exhaust fan on the roof is out, it will give you intermittent issues. The fan mixes or blends outside air with the return of the air handler, & duals to pressurize the attic. These were installed due to mobile homes built too air tight. Without this fan, your roofing shingles will curl, and your roof decking will bow prematurely.
Dec 22, 2012 | Coleman Mobile Modular Home Gas Furnace...
Coleman gas furnace model #8665d766,..the burner cycles great,...but fan motor will sometimes continue to run,..if you hit it on the front side lightly,..it shuts off...?
Hello, this sounds like it may be a problem with the relay on the integrated control board. it sticks occassionally and therefore the fan will keep running, when you hit the front side it causes the relay to open and thus the motor turns off. only option is to replace the control board as the relay cannot be replaced byitself.
May 15, 2011 | Coleman Heating & Cooling
The flame starts to fluter after 5 to 10 minuets and it trips the
i'm guesing this is in a mobile home.this furnace is hard to see the baffles.you really can't check baffles unless you get on the roof and pull cap and look down with flash light but that still doesnt tell much. have you checked to see if you have combustion air coming in to that room. if this is in a mobile home should be a flex pipe in ceiling or some times it comes from underneath make sure you have air from out side coming through. If this is a mobile home if you have alot of snow on roof this will cause the same problem you are having. i would check the flue and intake air first before i took furnace apart. Gas valve doesn't usually cause this problem. the repair guy is probally right but i would check the two thing i told you about first.
Dec 26, 2008 | Coleman Propane Forced Air Heater...
Coleman mobile home furnace Model #7966-756 will not turn on. The pilot light is lit, there is power coming to the step-down transformer inside the furnace. The reset switch is in the right position. It...
I had a similier problem, Check your neutral ground? also alot of power companies will come out and do a basic check of the voltages going to the furnace, and can offer advice for free.
Sep 17, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
221 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
