Question about Minka Aire F602-BNCH Gyro? Fan
Minka F602 - One of the two fans vibrates and makes noise.
One of the fans vibrates.  Upon close examination of the two fans, the fan that vibrates has uneven spacing between the blade housing and the motor housing.
Thanks for any help you can provide.
            Nate
    Problem Solver:
  • 7 Answers
With the power OFF, gently spin the working fan blade with your hand; use a wood utensil handle if need be -- you're doing this just Nate,
Try this:
get your eyes back to where you checked, and saw the uneven gap between the motor head and the fan head. Now, slowly turn the fan head to locate where the fan head is closest to the motor head. gently (use a thin, hard plastic spatula, for example) slip it in just a bit - right under where the gap's the narrowest, or to the sides of that spot, and taking your time, gently leverage the fan head up and SLIGHTLY past parallel -- be gentle, take yer time! Spin the blade head after each "adjustment", checking for parallel, or near-parallel operation ( should be on par with the functional one). It ought to work after just a few minutes of "tweaking".
It ought to work, especially if it USED to work fine (this assumes no outside force acted upon the fan head - meteorite, super-villian, etc)!!
**NOTE: after you've done the above, and it's spinning free, without looking "wrong" (like it's going to fall off!) PUT the GRILL back ON, and set fan to low it should turn normal!
hope this helps!
Posted on Jul 25, 2010
    Problem Solver:
  • 6 Answers
I don't understand what you mean by "uneven spacing between the blade housing and the motor housing." If physical spacing is the cause, then you should be able to fix it by tweaking the blade housing into a new position or re-mounting it by drilling new mounting holes of your own and using sheet metal screws to secure it.
The fan inside might just be unbalanced though. Try tightening the large brown peg on the back of the fan head, and try tightening any other small screws that you see holding the fan head or cage in place. Heck, maybe even loosen everything, reposition it a little, then re-tighten.
Balancing the individual fan blades would be tricky because they spin at such a high RPM, but it could be done by using a strong epoxy to stick the correct amount of weight on the blades that need it. Figuring how much weight to put on which blades would be the hard part.
Posted on Jun 11, 2009
Fans work but won't rotate
Probably needs a new receiver. Call Minka Aire
Oct 06, 2014 | Minka Aire F602-BNCH Gyro? Fan
F602 fans stopped working
It's hard to say - are you getting power to the fans? Check with a meter or test light.
Aug 07, 2014 | Minka Aire F602-BNCH Gyro? Fan
360 rotation
Call 1-800-307-3267 Minka aire. I think you need a new receiver.
Jul 24, 2013 | Minka Aire F602-BNCH Gyro? Fan
Minka gyro fan noise, my fan has a popping sound at the same point in each full rotation.
i'd take it back and get a replacement. It has a lifetime motor warranty. I used to sale Minka Aire but always had motor problems.
Apr 19, 2013 | Minka Aire F602-BNCH Gyro? Fan
Remove blades
I am having new blades sent from tech support, they broke. Call them at 800 221 7977. If over 1 year sense you got them, say how many units you bought and they might give you for free. Worked for us. Hopes this helps.
Aug 06, 2012 | Minka Aire F602-BNCH Gyro? Fan
Noisey Minka Aire Napoli ceiling fans
Minka fan are life time warrantied, have you tried contacting customer service... Minka fans motors have a very simply design... uninstall the fan... try balancing the fan on a table or some where that allows you to remove the shell that covers the main body of the fan... Carefully (someone that is very familiar with the electrical components.) soft wire the fan allowing you to see the motor as the blades turn... You will then see what is making the scraping noise... I may have some extra fan parts that you can easily replace... If you like to write me at payitforwardx2 @ gmail . com I am willing to try to further assist you...
Dec 27, 2009 | Minka Aire Ceiling Fan
Minka aire f602
There are tiny dip switches on the remote as well as on the receiver. Make sure they are set to the same sequence. The receiver is the black box that all the wires connect to in the ceiling.
Nov 02, 2008 | Minka Aire F602-BNCH Gyro? Fan
Traditional Gyro by Minka Aire - Just installed and does not work
I would triple check that the wiring is correct, then I would check the dip switches on the receiver and the wall switch to make sure they are set the same.
Apr 28, 2008 | Minka Aire F602-BNCH Gyro? Fan
Parts
Talk to customer service or sales. They can probably sell you those parts.
HEADQUARTERS
1151 W. Bradford Ct.
Corona, CA 92882
EAST COAST DISTRIBUTION CENTER
9348 D. Ducks Lane
Charlotte, NC 28273
--> TEL: +1 (951) 735-9220
FAX: +1 (951) 735-9758
EMAIL:
SALES DEPARTMENT:
sales@minkagroup.net
CUSTOMER CARE DEPARTMENT:
minkalaverycustomercare@minkagroup.net
Nov 10, 2007 | Minka Aire F602-BNCH Gyro? Fan
Minka Aire F602-BNCH Gyro? Fan Logo
351 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
