Question about Car Audio & Video
Radio volume on steerin wheel not working and only one speaker working
Bought a citreon xantia and the volume control for the radio on the steering wheel is not working and only one speaker is working
  • 284 Answers
If any of the other buttons dont work then it could be the connector on the back of the stereo
Posted on Dec 19, 2009
  • 518 Answers
TRY THE BALANCE CONTROL TO SEE IF YOU CAN GET BOTH SPEAKER TO WORK, AND MAYBE YOU HAVE A BUILD UP OF DIRT UNDER THE BUTTONS
Posted on Jun 13, 2009
Radio developed fault. Sudden max audio output which cannot be reduced by volume control.Just before fault, a click was heard in the back of the car.
If you have steering wheel mounted controls then play with the volume switch and see if that drops the volume, if not unplug the steering wheel control harness for the radio an if that makes no difference then the radio is defective.
Feb 08, 2016 | 2003 BMW 5 Series
Radio volume control on 2008 Subaru Tribeca does not work, but remote volume control on steering wheel works. Any suggestions on repairs?
Replace the volume control(rheostat) inside the radio. Only way to fix it. I would personally just live with it until one or the other quits working. Then replace the radio.
Jun 07, 2015 | 2008 Subaru Tribeca
Radio volume control on 2007 Subaru Tribeca does not work, but remote volume control on steering wheel works. Any suggestions on repairs?
Radio volume control on 2008 Subaru Tribeca does not ...
www.fixya.com/.../t25735073-radio_volume_control_2008_subaru_trib...
Jun 7, 2015 - Radio volume control on 2008 Subaru Tribeca does not work, but remote volume control on steering wheel works. ... does not... Replace the volume control(rheostat) inside the radio. .... Oct 09, 2014 ' 2007 Subaru B9 Tribeca.
Nov 04, 2013 | 2007 Subaru B9 Tribeca
Problem with steeringwheel control devices
can be various cause 1) power amp 2) control volume 3) speaker 4) wires or ribbon cable with bad contacts or corroded.see the diagram
God bless you
Jul 17, 2013 | Cars & Trucks
Citroen xantia steering wheel audio controls not working
it sounds as thogh the radio isnt the oe one and is not paired the remote is controled by the unit it may be a broken wire
Dec 04, 2012 | Citroen Xantia Cars & Trucks
2001 Town and Country Steering Wheel Radio Volume Switch Broke
The circuit for the switch goes through the clock spring contact is the likely cause of the switch not working, it is not connected to the wiring harness in the steering column that goes to the radio.
Sep 19, 2012 | 2001 Chrysler Town & Country
Removing steering wheel from 1986 model ford xlt spectron van automatic
first off the center cover needs to be removed from the steerin wheel. some can be pulled off and some have screws on the back side you remove then the cover will come off. once you determine that be careful the covers have control wires that are attached to it that go into the column. gently push in on the connector and turn counter clock wise and the wire will come out with the cover.you can usually rent a steerin whell puller from your local parts store and and use it to remove the steerin wheel after you have removed the nut holdin the steerin wheel on. if you dont have the puller, you can back the nut off to where its flush with the steerin shaft, then turn counter clock wise approximately another quarter turn and take a hammer and strike the nut and this usually breaks the steering wheel lose from the shaft. let me know.
Feb 11, 2010 | 1987 Ford Ranger
2005 Toyota Camry JBL Radio Replacement: Info button issue
Crutchfield sells an aftermarket kit that allows the steering wheel controls to work, but it's $74, and you head unit must be remote control capable. They also sell a wiring harness that works with Kenwood/Toyota as long as you have the original wiring harness that came with the Kenwoood. You'll need to do some snipping and krimping however.
Mar 22, 2009 | Car Audio & Video
Flashing sidelights on citreon xantia M reg
There's a button with a speaker with a cross through it on the dash to the right of the steering wheel.Should be the furthest button to the left.Turn yr ignition on and within 10 seconds press and hold this button till the indicator lights flash on the dash.Problem fixed.
Jan 14, 2009 | Remida Automatic Citrus Remuk4 Juicer
Radio controls work incorrectly
have you try having the steering wheel controls replaced? if so the problem is in the radio
Sep 17, 2008 | 2006 Honda Accord
Car Audio & Video Logo
94 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
