Question about Refrigerators
Our Dometic S1621 will not cool in the fridge or freezer.
We just bought this camper. On our maiden voyage, we discovered that even though all lights indicated that the Dometic S1621 was running like a charm that it would not cool. The camper is a 1994 Lumastar (not that that matters). We are at our wits end and sure could use some help to make our first camper a success. Oh and we do hear signs of life while it is on. There is a gurgling and burping sound, that would make one think something is moving in the back just not sure what. Thanks
  • aigon77 May 21, 2009
    Unfortunately the gurgling sound is the one you never want to hear from that type of fridge (RV). I just came back from the RV parts Dealer and the news are horrible...Your as well as mine fridge are shot, so save up $1200 or so to buy a new one.
3 Suggested Answers
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Posted on Jul 24, 2009
VtToolMan
  • 704 Answers
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
Where can i find a drip pan for a S1621 silhouette dometic rv fridge
use make and model number with brand and look in manual for it there should be a parts replacement list with phone number
May 26, 2014 | Dometic RGE400 Top Freezer Refrigerator
Domestic rc1180
disconnect thermistor from back board let run if ok replace thermistor if not replace cooling unit
Feb 09, 2014 | Dometic Refrigerators
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
Just bought camper, fridge lights show it is supposed to be operating. And pilot lights but no complressor kicks in. The area between the fridge and freezer gets warm, but there is no cooling in the...
Hi and welcome to FixYa I am Kelly. Locate the model number of the unit if possible and I will get you a manual. There must be battery power connected or the unit will always operate on gas.
Many other nice to know things in the manual....
Manual liink is here:
UK http://www.dometic.com/enuk/Europe/United-Kingdom/Customer-Center/Operation-Manuals/
^^ site also has US manuals, You have to select US under: Refrigerators - Caravan-Motorhomes-RV
Global by model number & product code
http://www.dometicmanuals.com/PROD/MASTERDometic.nsf?Opendatabase
If the manual does not help you respond here and I will assist you in troubleshooting.
Thanks for choosing FixYa,
Kelly
Jun 14, 2011 | Dometic Refrigerators
We have a Dometic RM2601 Fridge. won't
Check around the burner area for a yellow film the ammonia has leaked out
Jun 12, 2009 | Dometic RM2620 Refrigerator
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Silhouette by Dometic RV fridge
Tuna, it sounds like your thermistor is bad. Once the fridge reaches 40 degrees, the thermistor is supposed to tell the board to stop cooling and maintain. You can test it with an Ohmmeter.
May 07, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
279 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
