Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
I need a manual for operation & maintance of the 5500Watt port. generator.
  • 98 Answers
Here is the link to download the manual you're looking for
http://www.briggsandstratton.com/pdf/owners_manual/101/1933_0_om-Domestic.pdf
Posted on Oct 18, 2009
Where is the primer button on a Tahoe 7000lxh Diesel Generator
Scroll to the bottom of this page an down load both the engine maintance an manual for use.
Tahoe 7000 Series Disel Generator
Jan 25, 2015 | Diesel Electrical Supplies
Engine is blown what size brigsss &statton engine doi need
From what I can tell you have a model #212400 engine. Look for the model and spec numbers on the engine. They are usually either stamped into the top of the rocker cover near the spark plug, or sometimes on the housing that the recoil starter bolts to. You will need the spec number when you order an engine to make sure you get the correct one for that generator. I found all the information at this link which includes owners and parts manuals which may be helpful to you.
http://www.briggsandstratton.com/generators-pressure-washers/support/operators-manuals/?NTT=30242
Jul 19, 2011 | Briggs & Stratton 6200 Watt Electric Start...
I have a 5500Watt BSI550 generator that lost AC while in use. It's only putting out about 5VAC. I Tried several other capacitors and even without a cap it's still putting out about 5VAC right at the...
No electrical
output
1. Faulty receptacle. 1. Have Service Center
replace.
2. Circuit breaker kicked out. 2. Depress and reset.
3. Defective capacitor. 3. Have Service Center
replace capacitor.
4. Faulty power cord. 4. Repair or replace cord.
5. GFCI switch breaker kicked
out (if equipped)
5. Depress and reset
Apr 28, 2011 | Porter Cable 5,500 Watt Portable Generator...
How do i remove the motor on my briggs and straton 5500watt generator from the powercoil ive removed the generatior and coil from the frame as well as the outer cover on the coil what next i cant see...
Yes there is a special tool. I would recommend calling a dealer like www.arcolawn.com and ask for them to look up the special tool. Make sure to give the dealer your model and serial. Good luck
Joe
Feb 16, 2011 | Garden
Can i replace 4500watt elements with 5500watt on a 606 model
1) Manufacturer's warranty will be voided, and I've never seen recommendation that suggests better heating or saving money from replacing 4500W with different wattage element.
2) That being said, you have 240V water heater.
4500Watts divided by 240 = 18.75 amps
5500Watts divided by 240 = 23 amps
20 amp circuit breaker with 12 gauge wire is rated for 80% of load = 16amps
30 amp circuit breaker with 10 gauge wire is rated for 80% of load = 24amps.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
3) You can use 5500Watt element if you have 30 amp breaker and 10 gauge wire.
Feb 15, 2011 | RELIANCE ELECTRIC WATER HEATER
I bought a Generac 17kw with automatic transfer switch. I would like to use a 200 Amp manual throw transfer switch. The generator came with a pre wired sealtite pig tale and junction box. Inside the...
If you are using a Manual transfer switch, then you should manually operate the system. Why don't you use the switch it came with? Why would you use a 200a manual transfer switch on a 17kw generator? The idea is to move your critical circuits into the transfer switch panel. Then it would operate in auto.
Jul 02, 2010 | Generac Guardian 200 Amp Transfer Switch...
Want weld after i cut it off and restarted it moter runs no arc
push the reset button....im not sure where its located....but im sure you have one....
Jan 06, 2010 | Lincoln Electric POWER ARC 5500 HONDA
It is saying schedule maintance see owners manual
The manual should point out specifics but this is usually a message that is generated by the miles on the mill. Most important maintenance on a treadmill is keeping belt lubed. We also vac under the hood( motor area) to get out dust, lent and debris. and lube elevation mech. Check owners manual for type of belt lubricant.
Nov 16, 2009 | Startrac Fitness Products Lamar L1400...
Problem with power ausoutic 5500watt amplefier
With a 5500 watt amplifier you should be running 0 awg wire . You also need to be running an anl fuse holder with a 250 amp fuse underneath the hood by your battery. When the power light blinks like that it means that it needs more power - ie. that there is resistance some where in the system . With 4 gauge wire it just isn't getting what it needs. Make sure you upgrade the ground as well to 0 awg . If you have any other questions please feel free to contact me mmaudio545@yahoo.com
Aug 26, 2009 | Kicker KX1200.1 Car Audio Amplifier
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
275 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
