DVD keeps reading "NO Disk" eventhough disk is in unit.
Reads no disk, after I place it into slot. If needs cleaning eye can I do it. If so how. Thanks
Posted on May 30, 2009
Keep said no disk
It is not seeing or reading the disc, either a dirty or bad optical pickup in the unit----most likely bad and cheaper to buy a new player than fix that.
Dec 06, 2012 | Curtis Sylvania SDVD7014 DVD Player
I have a Samsung DVD R160 recorder. A few days ago the recorder was not on and it was making a noise like it was trying to read a disk. This went on for quite a while. I then turned it on and it would...
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
Jan 04, 2011 | Samsung DVD-R160 DVD Recorder
MY DVD-RE IS NOT READING ANY CD OR DVD..WHEN I M INSERTING ANY DISK IT KEEPS ON READING IT
Try using a Iris eye cleaning disk. Mosxt times when constant reading occurs or it says no disk it is the iris inside that has become occluded with dirt. Checkl that there are no finger marks on the disk and it is clean too
Once you have run the cleaning disk use a non scratched clean disk to check its load and read ability before trying in the disks that you had trouble with.
If they still give trouble then the problem will be with those disks and not the laser in the unit.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Samsung SH-S202J 20x DVD?┬▒RW DL IDE Drive ...
My dvd recoreder keeps saying cannot read disk. keeps ejecting disk when ever i insert a disk
get a laser lens cleaning disk .($2 to $10) . it looks like a standard CD but has fine little burshes that remove dust from the laser ...that may not work if anyone smokes around the machne .. in that case the cover has to be removed and the laser manually cleaned (with eye glass cleaning fluid on a soft paper towell) ..if that doesnt work then the laser may be just worn out ... replacement is usually more than the cost of a new unit ... make sure your disks are clean .. you can wash the shiney side with mild soap and water ... rince and pat dry .. dont use hot water ...
Apr 11, 2010 | Samsung DVD-R155
Dvd player wont read disk
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Apr 07, 2009 | Televison & Video
Dvd keeps reading no disc
It can be several reasons
1. Disk is upside down
2. Lens is durty. You will need to use CD/DVD cleaning disk for that
3. Disk is having diffrent region code or recorded in diffrent formate (for instance player playback disk recorded in NTSC, and you trying to playback disk in PAL formate)
4.Disk is recorded at higher speed (for instanse player markered X16, but disk is recorded at X24)
Good Luck
Dec 24, 2008 | Televison & Video
Unable to record,cannot read disk,is message on screen,
May be dust/dirt on the lens, so try blowing gently or using a DVD cleaner disk.
Oct 07, 2008 | Panasonic DMR-ES10 DVD Recorder
Curtis DVD player - Stuck in Load Mode so won't open - dvd inside - correctly seated - but may not be compatible. I just burned it & was testing it.) Have tried the paper clip in the tray release...
Do the following
Unplug power cord.
Wait two minutes and plug it back.
Keep repeatedly pressing the eject button while you start the unit, before it starts reading cd inside. Do this a couple of times.
If you cannot eject the disk in this way you will need to take unit apart.
Unit won't start until the disk is inside, as it tries to read the disk , disk is faulty and unit get stuck.
Aug 26, 2008 | Televison & Video
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
RIPED OFF BY BROADWAY PHOTO
Unit may have dust or contaminates built up on optical pickup. If you can reach the lens, try to very gently clean the pickup lens with a Q-tip. It is possible the unit has a defective turntable motor in which case you will have to have it replaced
Jul 31, 2008 | Video Cameras
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
