Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman 20.5 hp. auto trans.lawn tractor loss of drive power
Experiencing a loss of drive power on the transmission gets worse after running for a while. won't even pull me up any inclines.
Has new belt. Purged transmission, doesn't help. I'm fearing major tranny work. Makes kind of a whinny noise when put under a load, up hill ect. Unit used to fly up hills with loads of pulling/ pushing power.
Model # 917.270860
transaxle model # 319-0650
  • jguitar May 12, 2009
    I have my original craftsman manual with eploded view of the transmission. I don't see any internal pump in the transmission. unless i don't know what I'm lokking for
  • jguitar May 14, 2009
    I hate to be a pain but, I also see #13 as a block cylinder assy. should this also be changed, and what other parts should be looked at for wear and changed? Is there a repair manual avlailable for this model either on line or in book form?
    Thank you so much for you help
  • 246 Answers
Hello:
>>You can View a Breakdown/IPL of
this Engine at this Site Addy,
http://www.outdoordistributors.com/
and Select the H. Then Select Hydro-
Gear. Then Select Don't have Part
Numbers. Then Enter the Model
Numbers 319-0650. Then Select your
Model and Download the File for
Online Viewing.
From your Description it Sounds like the Internal Pump is Worn and is Loosing Pressure as the Unit Heats Up and the Components Expand from the Heat.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • John C Bridgers Sr May 14, 2009
    Hello Again jguitar:
    The Pump is # 23 (Block-Cylinder (Motor) Assy) in the Breakdown.
    >>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
My Craftsman lawn tractor with 19 horse B & S Twin with hydrostatic transmission loses speed and power in forward and reverse as it warms up. Within 20 minutes reverse will be gone and forward mo
more than likely your low on transmission fluid. I heard alot of this pertaining to hydrostatic transmissions on yards with inclines. I would check your fluid level .
May 14, 2014 | Craftsman Garden
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Power loss
sounds like the engine is running lean caused by dirty jets inside the carb
Aug 08, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Lawn Tractor 17hp 42 model 917.271662 auto trans idles and bucks when cutting grass
The symptom that you are feeling is that your transmission is not fully engaging correctly. Basically you have a few different things to try depending on the trans that is on your machine. Drain the fluid and re-install new fluid, adjust your brake/clutch to make sure that you are fully disengaged and fully engaged when you release the pedal. If none of those 2 cure your issue then you are looking at a trans rebuild or replacement
May 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My mower with auto. trans. won't go forward or backwards.
Here are a couple of things. Make sure the "neutral" lever for the transmission is in the engaged position. Also if anyone has removed a rear wheel recently, make sure the key is in the slot that locks the transmission axle to the wheel hub. If this is missing the tractor will not move. These are two simple things that need to be checked first. Hope this helps.
Feb 17, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a Craftsman lawn tractor 21.5hp (hydro stat. trans.) I've noticied a small loss of power over a few yrs. Now I have no forward gear at all, I still have reverse, fluid level is up no sign of loose...
If you had included model no. I could have been more help but you probably will have to replace drive plate and or more in transmission. If you go to searspartsdirect.com and in model number type in, hopefully you will get parts breakdown of the transmission showing parts.
Oct 22, 2017 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman lawn tractor model 917.270821 ( Auto trans)
Check the fluid level in the transmission. If the fluid level is low, the trans will act as if it's slipping.
Nov 25, 2009 | Vacuums
Transmission reverse and 1 st gear, 20 hp
transmission and shifting problems are tricky. from the limited information given, i'll go on assumptions - if this is a hydrostatic transmission, your brake is stuck, it will need to be adjusted - if it is a six speed, several factors come into play. if it will shift okay with the engine OFF, but not with it running, you have a belt problem. has the belt been replaced recently? is it the correct belt? is the belt routed correctly? if none of the above, check the belt guides to make sure that a stick or something hasn't poked up there and bent them. their purpose is to make the belt "blossom" away from the engine pulley so there is no tension on the belt at the transmission. if it won't shift with engine off, the shift shaft in the trans is probably rusted and sticking.
Jul 01, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Automatic Transmission is squealing and bogs down when under load
Check the trans drive belt, most likely that, or a worn tension pulley. check easy things first. Try pulling back on foot pedal to give belt a bit more tension.
If the trans looks clean and no leeks start with the belt.
Nov 07, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
957 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
