The tv is rolling and seems to a little dark, I found a small hole in the back of the tv with verticle hold words above it but can't find a button...HELP PLEASE
My tv is rolling and looks a little dark , I can't the vertical hold button. Its an rca
nfandres
  • 168 Answers
SOURCE: Quasar 32" TV VERTICAL HOLD
well most of the modern tv today doesnt have vertical hold anymore. this symptom is caused by a trouble in the IC integrated circuit or the vertical oscillator circuit. let the service guy do the job if u dont know anything about this. good luck!
Posted on Feb 02, 2007
techman
  • 3130 Answers
SOURCE: RCA P52939 projection TV
Yes you are correct, no days these TV sets have an automatic vertical hoild, and no I am sorry to say, there is no adjustment for you to make. there is a problem in the PIcture in picture circuit if there is one or the sync sepaqrator circuit has a problem. most likely a bad capacitor or a bad diode. This is a solid state set and there are no user replaceable parts inside them unless you know how the circuits work and can trouble shoot printed circuit boards. You are best to call in a pro to assist you in this repair. Good Luck
Posted on Mar 23, 2007
  • 579 Answers
SOURCE: older toshiba tv cx32621
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Posted on Jan 03, 2008
SOURCE: vertical hold problem
Maybe sync separator transistor is faulty
Posted on Jan 08, 2008
  • 375 Answers
SOURCE: picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Posted on Mar 27, 2008
Dark Screen
It sounds like a back-light problem. Check all the CCFL back-lights.
May 08, 2013 | Samsung LN52a750R1FXZA
After tv has been on for a while the picture goes in and out of multi colored verticle bars with horizontal rolling.
Thats problem have lost of harizontal sync.Try to adjust the horizontal hold until the picture back to normal.
Jul 05, 2011 | Televison & Video
Screen rolls and jumps
look at the back of your tv and see if you have anything in relations to verticle hold or horizontal hold. it would look like a round piece with a flat to put a flat screwdriver into . this way you can adjust your screen etc.
Mar 12, 2010 | Naxa Electronics NX-503 Television
I cannot find vertical hold
The sync is automatic. There are no knobs to turn. If the picture is rolling, look first to the source connection and make sure your tv has a solid vertical sync connection. If you are using the RF input then the issue could be within your small signal board also known as the SSB. Good luck.
Mar 23, 2009 | Televison & Video
What causes the screen on our singing machine stvg1008
My machine has a button on the back just like a TV that controls this. Chech yours out and see if it has the same.
Mar 04, 2009 | The Singing Machine DVD/CDG Karaoke System...
Logik lt2974 small picture
the problem is in the verticle section, if you are a technician check a verticle IC and a capacitor of that stage. to allocate a verticle stage follow 4 cables coming down from deflection coils, two of these wires goes near transformer, this is horizotal and the other two goes near an IC this is verticle. positive idea.
Nov 22, 2008 | Zenith B25A02Z TV
The picture rolls vertically sometimes.
I would check the capacitors in the verticle deflection circuit. Also try resoldering the verticle output as well as the verticle yoke pins where they connect to the chassis. Mitsubishi has had some trouble with their capacitors, you may have one that is leaking. Let me know if I can help you further.
Jan 13, 2008 | Mitsubishi VS-60801 60" Rear Projection...
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
