Question about Kenmore 73932 Gas Dryer
Our gas was recently off and turned back on the other day. The gas dryer is not working now. Is there something that has to be done to get heat?
    Brigadier General:
  • 8,619 Answers
Hi
Please check the things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on May 10, 2009
I have a Maytag dryer model DG412 that recently stopped heating. I replaced the igniter and it worked for a few minutes then stopped again. When I removed the igniter it broke into pieces.
Usually if it heats for few minutes then doesn't relight one of the coils has gone bad. They come as a pair as you know somake sure you replace both. You have done everything right so far... You do have bad coils though.
Dec 09, 2016 | Maytag Dryers
Good day, I get no warm air into the dryer, what can be the problem? what can be done? Thank you, Liam Manor
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 05, 2010 | AEG T57800 Electric Dryer
Lp gas dryer. sometimes when drying smells like butane lighter. venting is wright i think i followed manuel for correct length of venting.maytag dryer 8 years old. thank you
If you have recently painted or varnished something in your house the fumes could be the cause. They react to the heat in the dryer. Let the house air out for a few days.
May 07, 2010 | GE DBXR463GB Gas Dryer
KENMORE 80 SERIES GAS DRYER RUNS BUT DOES NOT HEAT
You have a defective gas valve solenoid. If you have an appliance repair center in you area, go to the parts dept, give them your exact model number and they should have the part you need in stock. The solenoid is easy to replace....you can do it yourself and save some money..
Good Luck,
Eric
Jul 09, 2009 | Kenmore 72802 Gas Dryer
DLG2532W Loss of heat
I had same issue and cleaned out all lint from the entire cavity of the dryer. Fixed the problem.
Jul 08, 2009 | LG DLE0332 Gas Dryer
My dryer will not heat up
You don't wan't to mess with this. Its probably something small like a defective thermopile, but repairs around the gas valve should be done by a professional. The thermocouple and photocells are safeties.
Apr 26, 2009 | Dryers
Dryer won't heat
Hello tfulton1963,
The fact that it worked for 3 days and then failed suggests that it is probably something else. You may have a non-resttable thermal fuse that opened or the gas valve itself isn't functioning. Can you see the glow of the igniter when it starts? Are you sure the burner is getting gas from the inlet valve?
These are the basic components to investigate.. Let me know the outcome of these checks and we can get you going again if none of these work.. Regards
Oct 10, 2008 | Amana NDG7800AW Gas Dryer
Kenmore 73932 Gas Dryer Logo
20 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
