Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Is this for only Craftsman products? I have a murry 42" riding mower, stays in nuetral, gears will not engauge. Can you help me?
  • 246 Answers
Hello:
From your Description it Sounds like the Shifter Rod has Broken Inside the Transaxle or the Shift Keys have the Shifter Lever Locked in the Neutral Position and the Keys Require Replacing.
>>On the Transaxle is an OEM Identification Plate. Send me the Information Off of This Plate, Please. With this Information, I can Locate the Proper Manuals and Better Assist You.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
I have a craftsman LT-1000, I can't get it to release the tires, they stay locked even when relesing the lever
if this is a 6 speed or anything but hydro be sure its in nuetral
if it has nt been moved in awhile be sure belts arent stuck to pulleys
Sep 14, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do i know if relay is gone on my craftsman ride on mower
If you can access it? check the purple exciter wire to the solenoid with the parking brake set. machine in nuetral and the key switch to the start position, with a 12volt test light see if you have power that wire? if not you probaly have a bad safety switch (brake or nuetral start if gear drive) if you do have power then try to jump accross the 2 main post on the solenoid if it turns over your solenoid is bad if it doesn't then it is a good posiblity it is the starter. Then try to run 12 volts from the positive terminal on the battery directly to the main lug on the starter. I hope this helps!
Aug 21, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My blades stay engaged at all times model # 917273012
if the blades are staying engaged all the time try and unplug the switch if they still stay on you have a short also try getting off the seat that should shut them off as well shifting into reverse should shut them off as well if they stay on threw all that you have a shorted wire in the system
Jul 09, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Linkage inside gear box does not engauge. Mechanics work to the bolt on top of the bottom gear (differential) box. Neither forward nor reverse work.
Most likely a hydrostatic transmission and most likely it is dead. Buy a new one or look around on google and craigslist for a used one. Maker and model number will be printed on top and possibly stamped on the bottom. New hydrostatic transmissions cost more than a new mower.
Mar 31, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lt1000 hydrostatic drive stuck - will not engauge or disengauge
Does the tractor try to move or **** in any direction, if so you may want to check to see if the disk that controls the brakes is stuck, I've seen this many times.
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a murry tractor and i need to know the weight
In general, the Murray tractors should weigh between 275-375 lbs.
Nov 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
149 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
