Question about Microwave Ovens
Fire in microwave
My hubby put something in the microwave that had an inner wrapping of foil. There was a fire in the microwave and now it won't turn on. Nothing seems to be melted, just scorched. We cleaned it and now there is no scorch smell inside. Could it be the fuse?
  • 180 Answers
Do not put any metallic objects or substances in side the oven . It will produce arcing inside the oven. Take care in future.
Posted on May 11, 2009
Fire in microwave
You cannot put any metal objects in the microwave. And that includes aluminum foil. Or time to get a new one.
Apr 15, 2014 | Frigidaire PLMV169DC Microwave Oven
Microwave doesn't work after press the start button
Blown fuse inside the oven. If you can do electrical work, repalce it. I wrapped mine in aluminum foil as a quick fix, as I understand the very high risk of fire and possible death from doing so.
Nov 21, 2013 | Sharp R-408J Microwave Oven
Heat: I placed a microwavable food product in my sharp carousel r-1505. there was a tiny piece of the foil still attached to the rim of the product container. upon start, the foil immediately caught...
Maybe. The presence of metallic material (foil, stainless steel silverware, etc.) in an operating microwave oven creates electric arcs between the foil and the inside wall of the oven. And this can destroy the electric components.
Sep 22, 2013 | Sharp R-1505 Microwave Oven
I put a metal pan with food inside my microwave oven. I heard a popping sound and there are now two tiny black marks pitted into the glass on the door. I can feel the two pitted marks from both inside...
Yes it is safe to continue using the Microwave as long as the integrity of the glass is not compromised and the pitted marks do not exceed 1/4 inch. The RFwave generated by the magnetron is a pretty wide RF wave beam.
If your really concerned you can take the unit to any appliance service center and ask that they perform an RF leakage test. There is really no other way to know if your leakage is within acceptable limits. I can tell you from personal experience that the ony microwave I ever saw demonstrated excessive leakage had either been dropped and had hinge or latch damage.
If your really worried about it and can not get to a service center you can do this test:
- Wrap a tall empty glass with a sheet of aluminum foil and place it about 3 inches away from the microwave in front of the area you where noticed the pitting.
- Run the microwave with a GLASS filled with water of equal size for 1 minute.
- Stand back 3 to 4 feet and watch for any signs of a spark on the aluminum foil.
- As soon as the microwave shuts off check the dry foil wrapped glass for any signs of heat.
(No heat.... no problem. Sparks or Heat = repair time.)
Thanks for choosing FixYa.
Kelly
Sep 21, 2010 | Sharp R-1480 Microwave Oven
Hamburger in foil wrap put in microwave - shorted unit out
Hi- The first thing here is safety. If the power supply is good- 120v at outlet- then address the fuse in the cabinet. Open door, remove screw(s) holding control panel, and tilt out panel. Fuse should be visible. Check for continuity. If bad, replace with 15amp appliance fuse. Plug in and check for operation. If fuse blows again, unplug and start looking at a new microwave. Let me know if this info helps. Have more if needed- Thanks- Ed
Mar 15, 2010 | Whirlpool MH6141XK Microwave Oven
My nanny stuck a piece of chicken wrapped in aluminum foil into the microwave for 30 seconds ... naturally: diasaster .... the front glass is 'burned' in a small spot but I think it is a 'hole' ... still...
There is a plastic inner sheet that covers and protects the metal mesh that's in between the door panels.
If food, grease, or moisture gets on the metal mesh, it can be damaged, which can cause leakage, resulting in arcing and possible fire.
So the inner sheet must be repaired or replaced.
If the hole is not too big, you can use an Xacto knife or razor blade to cut away the damaged part, then clean & dry it thoroughly, and apply a small piece of clear packing tape over the area.
Otherwise, you can replace the sheet.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 06, 2009 | Whirlpool Microwave Ovens
Will tin foil in the microwave ruin it completely? The microwave turned off after my son mircowaved a potato wrapped in tin foil.
You should always put a spoon in a cup of liquid that you heat in a microwave oven.
The microwave with a potato wrapped in tin foil is like operating the oven with nothing in it! If the microwave was spotlessly clean then your in trouble.
1 put a cup of cold water in the microwave and set for 5 minutes. if the water boils then your lucky if it cold then go and buy a new microwave and stop your childs allowance for a fortnight.
One might ask the question how old is your child and should they be using such a machine unsupervised!
Nov 05, 2009 | Microwave Ovens
I have a GE convection/microwave.when you turn it on fire starts flashing inside.
hi my name is mark, the flashing you see is because something inside the oven cavity has acted as an antenna and all the microwave energy is going to ground. check for foil. if inside of oven is really dirty it could cause problems. if you cant find problem easily the oven will need to be disassembed. replacemant my be easier.
Mar 15, 2009 | Microwave Ovens
Microwave oven
If you put metal, like an alluminium foil into microwave, the magnetron will start arching, and you will damage magnetron, diode or capacitor.
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Jul 24, 2008 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
143 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
