Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Model 1699 bissell proheat clear view with heater
I have a Bissell Model 1699 when I removed the pump to this unit to go buy a replacement I wrote discriptions of where the disconnected hoses went. Apparently my descriptions were poor. Now after switching the hoses all around I am not sure where they go. I cant get the thing the thing to go backt together because apparentely the hoses arent routed properly How can I find out where they are supposed to be connected and how they are routed.
  • 2 more comments
  • Spidey54 Feb 09, 2008
    Model 1699 bissell proheat can't fixure out how to put back together the water cleaning switch.. How to line it backup right?
  • e-spangler Aug 30, 2008
    i have a bissell pro heat turbo and it does not spray any water out i get cleaning stuff but no water.
  • latinfromtam Oct 17, 2008
    i too have the same problem
  • gamber Jan 09, 2009
    my bissell will not spray out any soap or water or anything ive taken it apart and no luck
    President:
  • 1,673 Answers
Hope this picture will help:
Posted on Jan 17, 2008
Flow meter inop can not use cleaner because will not spray
Posted on Oct 13, 2008
How do you replace the water pump in the bissell 1699
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dj
May 09, 2010 | Bissell 1699 ProHeat Clear View Upright...
Need a manual for pro heat brissell model 1699
heatman101
reyy536
Mar 05, 2010 | Bissell 1699 ProHeat Clear View Upright...
Water comes out the accessory hose but not the floor cleaner
I had the same problem and the heater ports were clogged. I took apart the top unit and cleaned the ports with miniature bottle brushes used to clean spray painting equipment (purchased at Harbor Freight for $4). Reassembled and the unit worked fine.
Feb 07, 2010 | Bissell 1699 ProHeat Clear View Upright...
Water and cleaner dispenses from handheld attachment only
He could be right but most of the time when it doesn't dispense water and cleaner it means that the pump belt is worn and needs to be replaced. I would try that first (only $4.99) before I spent $100. Here is the pump bet you need, it comes with instructions:
Bissell 1699 Proheat Belts
Dec 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Model 1699-1 ProHeat Clearview Plus -water and cleaner do not dispense when using trigger on handle. The turbobrush hand tool works fine.
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
All lines are clear and the darn thing still won't
The reason it won't dispense solution is because the pump belt is worn or stretched. You need to replace it. Here is a link to the belts you need and a manual you can view:
Bissell 1699 ProHeat Belts and Manual
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Water is not going through the machine
The pump belt may need to be replaced. You can get the belt and view the manual here:
Nov 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat model 8910 water will not come
  • check pump belt
  • seat tank properly
  • check tank filter
i have repaired many of these and found that 90% of the time its the pump! #41 on diagram < click
9% its the heater clogged up #65 on diagram < click
1st check the small problems i wrote above
if all else seems fine start by removing the heater and disconnect the hoses from it. blow through one end of the heater (should be no restriction)
Oct 08, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
1,088 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
