Back to:
Tags:
Cambridge Soundworks Seventeen Speaker
4 speaker/2speaker problem
By Bouncy - usenet poster
i have a soundblaster live (pci) on a windows xp pro computer.
i have 4 cambridge soundworks speakers with a subwoofer attached to the
sound card.
if i go to the control panel and into the sound and audio devices .. and
click on advanced and set it to quadrophonic speakers (4 speakers) i get
audio from all 4 speakers and the sub. but sometimes when i reboot i
wind up back at 2 speakers again (or desktop stereo speakers) .. how can
i get xp to default to the quad speakers? instead of dropping back to 2
speakers like that?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Melissa
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
D o t A u wrote:
nope not muted.
just set to 2 speakers.
i've double clicked on the sound icon in the system tray (bottom right
of the desktop, and also gone to the control panel -> sound and audio
devices
nothing muted. but good suggestion.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 4 speaker/2speaker problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
M0nica L
Rating: 0%, 0 votes
Onboard sound can cause the problem you describe; disable it if applicable.
Some Big Cunt
Thank You!
Solution #3
Not Rated (0)
Kim1
Rating: 0%, 0 votes
On Wed, 29 Oct 2003 19:17:37 -0600, Andrew <spec @chartermi.net>
wrote:
Then go into the speaker surround mixer and switch them on from there
a little bit of messing around and you wil get the rears to work,
I had this crap with the audigy 2 card, Just because I was running 4.1
setup instead of 6.1 It turned the rears off and I ended up with just
2.1 Very annoying ! A buggy software issue I beleive so try to
download all the latest updates and see what happens
Rotor:-
Thank You!
Solution #4
Not Rated (0)
Cornish
Rating: 0%, 0 votes
What about is the volume control??
Make sure they're no muted..
D o t A u
"The strong must protect the Sweet."
Thank You!
Solution #5
Not Rated (0)
Joey2
Rating: 0%, 0 votes
Yeah I have a Hercules Muse 5.1 DVD.. Aka C-media...
Xp always defaults back to 2ch.. But it's doesn't actually matter.
I still always get 5.1..
D o t A u
Thank You!
Solution #6
Not Rated (0)
2Pansy
Rating: 0%, 0 votes
On Wed, 29 Oct 2003 13:10:10 -0600, Andrew <spec @chartermi.net>
wrote:
Xp sometimes does that, Ignore it as you still work in quad mode,
I have SB audigy and Xp finds quad speakers automatically so I assume
its a software problem with lesser cards!
Thank You!
Solution #7
Not Rated (0)
Brad
Rating: 0%, 0 votes
i do thank both of you for your help.
but actually no i only get 2 speakers and a sub. there is no sound at
all from the rear 2 speakers.
Thank You!
Solution #8
Not Rated (0)
jessie25
Rating: 0%, 0 votes
Well, Audigy is 2, 2.1, 4, 4.1, Surround, 5.1, 6.1 and 7.1...
Xp supports 7.1... So does this mean you have a "lesser cards" too??
D o t A u
Thank You!
Can you Help with these Home Theater Speakers and Subwoofers problems?
Problem is T6060 comes with the three pin which are...
I want to replace the speakers in my towers and i need to...
I only get sound from the Direct and Stereo settings on my...
It sounds like static electricity being discharged after a...
I had ordered the Curtis HTIB 1000 5.1 CH SPEAKER SYSTEM...
Loading problems.
Repair Service
Find Home Theater Spe. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
