Question about ASUS G1 Notebook
Black screen startup
For the past two days, when I start up my ASUS G1 the screen shows no video. I can hear the ASUS startup sound but no picture (and no windows startup sound). If I leave it on sometimes the startup sound will sound again. The day it died on me it had done a weird split black screen, I restarted and everything was okay. Then when I shut it down the screen stayed black. I tried again and it worked. Now, there's no way to get it to work. I've tried taking out the battery and power cord, left it for hours. I've tried blowing out the fan incase it was overheating.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Hello..this is the 1st you need to try..if you have a CRT monitor or LCD Screen try to put the signal Video on the Laptop located at the Back of unit then try to boot your unit...Thanks...
Posted on May 10, 2009
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Ideapad s10e black screen
Hook a monitor to the video output, if picture is present it means the inverter board is the most likely problem, [located under the screen] the second possibility is the backlight behind the display. Now if both screens show the same symptom it is the video graphics chip.
Jun 27, 2012 | Lenovo IdeaPad S10e Netbook
My asus u52f-bbl9 doesn't want to move past the boot screen
Have you tried booting into Safe Mode?
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
If all fails Sounds like your operating system needs to be reinstalled or you can do a system recovery to set it back to when you first bought it.
Apr 09, 2012 | ASUS U52F-BBL9 Laptop
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
My screen is black with no picture
If you turn on the computer and the lights come on and the fans start but you see no picture, try turning up your volume to listen for the windows startup sound. If you hear the windows startup sound it is likely your video card or the monitor on the laptop. If you hear no sound the power could be faulty or the computer could be completely fried. Follow this link to get your laptop taken care of by HP http://h71036.www7.hp.com/hho/cache/405979-0-0-225-121.html
Mar 15, 2011 | HP Compaq nc6120 Notebook
Asus Eee pc 900. Boots up but after booting only shows black screen. How do I fix this?
If you are only getting a black screen and you are sure it's booting (how do you know?), then the problem would be the incorrect video settings in Windows. In this case, you might try starting in safe mode and resetting the video adapter.
If you see stuff on the screen as the system boots but then it goes black, then it's definitely a Windows issue.
If you see nothing at all but hear the system starting, then it's a hardware issue involving the video card.
Aug 06, 2010 | ASUS Eee PC 900 Notebook
Monitor shows nothing can hear the sound effect when asus logo should appear and nothing black screen
Try to hook the computer to another monitor, this will tell us if the video card on the motherboard is shot, or just the screen is bad.
Oct 09, 2009 | Computers & Internet
No video at startup, black screen
your video card probly went try to get into dos and run a check or just replace the card
Aug 26, 2009 | ASUS G1 Notebook
My xbox wont show on my tv,cant hear sound but no
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
May 12, 2009 | Microsoft Xbox 360 Elite Console - Black
ASUS G1 Notebook Logo
938 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
