Question about U-Line Icemaker
Defrosted and now it won't make ice again
We defrosted our U-Line WCM48A ice maker and now we can't get it to make ice again.
  • Defisher May 12, 2009
    I also turned it off to defrost, and now, it will not even get cold inside.
  • 286 Answers
If the compressor or fan isnt running. Check your ejector blade in your icemaker.It should be at 12 oclock. If it isnt then remove the cover of the icemaker and turn the smaller gear counter clockwise until the ejector blade gets to the 12 oclock position. This should start the unit.
Posted on May 13, 2009
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
Kenmore Model:106.56612500 side by side refrigerator ice maker not working .Possible water valve ,possible ice maker ,possible frozen water line .Ice maker is in the the freezer box not the door What is...
cheapest and up,, check for a frozen water line, defrost the entire unit, any of the components can be iced up, once defrosted,, if you still have a problem, then check the inlet valve ,
Jul 22, 2011 | Kenmore Side by Side Refrigerator
Should I just junk this frig? We turned frig off manual defrosted and cleaned out plugged up line from freezer to frig. Frig and freezer worked fine for one month and then the same problem has happened...
Hi this probably has a bad defrost thermostat, its only a $10-15 part its located in the freezer behind the rear panel. Would need to be totally defrosted beore you changed it and usually requires a bit of wiring but nothing complicated just need to be handy with wire strippers.
Sean
Mar 27, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker level arm froze up. I defrosted with a hair dryer last night, but no ice was being made this evening. I defrosted again and now have an ER 15 code on the control panel. It appears that the...
the problem with using a hairdryer is that although it defrost what you can see in dont that what you cannot....and youve guessed ....it turns back to ice as soon as you switch it back on ....you have to do a complete defrost(24hours)with the doors open.then dry out with towels then restart.....
Sep 21, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
DEFROSTED WATER DOES NOT DRAIN TO PAN
Remove the food and the ice maker from the freezer ( if equiped ) and the bottom panel . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER ( ground wire is good ) solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
May 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator Freezer has ice forming in the bottom inside freezer section. It appears to be leaking down the back inside compartment. The top section has an ice maker and water dispenser but I haven't had...
I believe you just described a defrost condensate blockage that is causing the leaking. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan, water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Nov 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker stopped working
You need to defrost the freezer. By the door being ajar, there was excessive ice build up on the coil that was not removed during a system defrost resulting in a blocked coil. This caused the temperature to rise in the freezer above twelve degrees that is why the ice maker stopped.
May 19, 2009 | Sub-Zero 561 / F
SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Mar 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
How do I get water line to ice maker defrosted?
you will have to remove the Ice maker and the use either a hair drier or shop vac the blow air onto the line unit it thaws. Have a Merry Christmas and thanks for using FixYa.
Dec 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
U-Line Icemaker Logo
205 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
