Question about Sony VAIO VGN-FS840/W Notebook
Sound skips and drags
I have updated and re-installed the drivers for this, but it still drags and skips on playback. Regardless to whether I'm playing a CD, DVD or just listening to music online, the playback does the same thing.
Please help.
  • Anonymous May 21, 2009
    Exact same problem. . . Sony Vaio laptop sound drags (stutters) a lot. I, too, have uninstalled/reinstalled drivers with no luck. I even went so far as to wipe the whole thing and start over. . . it was fine for a brief while and then right back at it. HELP!
My headfone ok i can listen other by headfone but my microfone driver not working i wanna update micro fone driver
Hi phool0055 ,
There is nothing as a separate microphone driver that you need to install generally ,
All you need to do is check microphone settings , as to whether they have been changed or the microphone has been muted accidentally.
Please follow the below steps :-
  • In control panel , open sound speech and audio devices
  • The click on the audio , tab where you would find two options , sound playback and sound recording.
  • Sound playback has to do with the sound that you hear , i.e. the headphone sound.
  • Sound microphone has to do with the sound that you record or transmit i.e. microphone.
  • Now you would have two options under sound recording sections, namely volume and advanced.
  • Open the volume and advanced section and check if it has been muted.
  • If it's muted , please unmute it and now you would be able to record your voice or chat using a microphone.
Hope this helps ..:)
May 09, 2011 | Computers & Internet
Sound quit workong, card will not enable. Installed new card, same thing. What's up?
First we have to determine whether or not you have the required drivers installed in order for the operating system to communicate with your sound playback device. Following is the keyin sequence for Windows XP - The key-ins will differ somewhat for other Windows operating systems:
Click on START
Right Click on MY COMPUTER
Tnen click on PROPERTIES followed by HARDWARE and then DEVICE MANAGER.
Double click on SOUND, VIDEO and GAME CONTROLLERS
Your sound playback device (Soundblaster) should be listed. And there should NOT be a yellow exclamation mark in the left margin (If there is, this is an indication that the device is not working properly - see CORRECTIVE ACTIONS below.
Double click on your sound playback device.
In the device status box you should see the statement "This device is working properly"
If you get any other messages indicating that drivers are required or need to be updated, see CORRECTIVE ACTIONS below.
If everything look OK, click on the "X" in the upper right corner to close device manager.
If everything was OK in device manager we will now see if the operating systen is sending sound to your playback device.
Click on START
Click on CONTROL PANEL
Select the Classic View (If not already displayed)
Click on SOUNDS AND AUDIO DEVICES
Double Click on AUDIO DEVICES
Click on the AUDIO tab.
In the Sound Playback dialog box your sound device should be listed. If it is not, click on the pull-down menu and select it if you can..
If it is NOT listed, see CORRECTIVE ACTIONS below.
If it is listed, perform the following tests:
Click on the SOUNDS tab
Set the Sound Scheme to WINDOWS DEFAULT
Click on APPLY and OK
In the Program Events dialog box, click on any event that has a speaker Icon to the left of it
Underneath the Program Events dialog box you will see a small box with a triangle inside
If the triangle is black that means that the operating system has recognized your sound playback device (sound card).
Click on the triangle.
You should hear the sound through your speakers (the triangle will change to a rectangle while the sound is playing)
After the sound plays the black triangle will re-appear.
If the triangle is black and changes to a rectangle when you click on it and you DO NOT hear sound through your speakers either your speakers are plugged into the wrong jack or you have a problem with your speakers. Test or replace the speakers.
If the triange is gray that means that the operating system does not recognize your sound playback device (sound card). See CORRECTIVE ACTIONS below.
CORRECTIVE ACTIONS
If your playback device is installed and enabled and either you have an error indication, drivers are not installed, or device manager reccommends a driver update, you will have to download drivers from manufacturer's web site. For soundblaster your link is http://www.creativelabs.com/support
Also, if the drivers are installed and you no have no error messages, but you do not hear sound when you click the black triangle, you may have a hardware conflict between your sound card and another device. At this point, you will require some help from a qualified PC technician.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Dec 31, 2010 | Creative Labs Computers & Internet
How can i fix my audio suon
Method 1: Restart the computer Restart the computer at least one time after you install a Windows Vista service pack to verify that all processes related to the installation are complete.
After you restart the computer, determine whether you can hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 2. uparrow.gifBack to the top Method 2: Try another sound deviceIf it is possible, try plugging a different sound device into the computer. For example, if you were using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the sound device.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original sound device and the issue is resolved. If you cannot hear sound, plug the original sound device back into the computer, and then go to Method 3. uparrow.gifBack to the top Method 3: Unplug the computer speakersUnplug the computer speakers or other sound devices that you may be using, such as headphones, from the computer and then plug them back in to the same port. Most sound cards that are compatible with Windows Vista include a feature that detects sound devices plugged into the audio jack. This procedure may prompt the audio detection feature to detect and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4. uparrow.gifBack to the top Method 4: Verify that the default sound device is set correctlyAfter you install a Windows Vista service pack, you may find that the default sound device, also known as the playback device, was changed. You may also find that the sound quality has changed. Make sure that the default sound device is set correctly for the sound device that you are using. To set the default device, follow these steps:
  1. Click Start vistastartbutton.jpg, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected. Follow these steps:
    1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect. When you finish, close this window to return to the previous window.
    2. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
    If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  4. Select the sound device that you want as the default sound device, and then click Set Default.
  5. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5. uparrow.gifBack to the top Method 5: Verify that a sound driver is installedWithout a sound driver, you will not hear sound. Make sure that a sound driver is installed. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type Device Manager in the Start Search box, and then press ENTER.
  2. In the Device Manager dialog box, expand Sound, video, and game controllers.
    If there is a speaker icon next to the sound driver, the driver is installed. If there is a yellow question mark next to the sound driver, the driver is not present or will not load.
Go to method 6 to reload the current sound driver and test for sound. uparrow.gifBack to the top Method 6: Reload the current sound driver If you discovered in method 5 that the sound driver was not installed, or if you discovered that the sound driver was installed but is not working, try to reload the sound driver. To do this, follow these steps:
  3. Locate the audio device that was included with the computer.
  4. Right-click the device, and then click Properties.
  5. Click the Driver tab, and then click Uninstall.
  6. Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
  7. In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
    You receive a message that states that a hardware device is being installed, and then the uninstalled audio device appears in Device Manager.
  8. Close the Device Manager dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If the current sound driver did not reload or if it did reload, but you cannot hear sound, try method 7. uparrow.gifBack to the top Method 7: Update the current sound driver If the current sound driver does not seem to be working, see whether there is an updated sound driver that you can install. To request an updated sound driver, contact the manufacturer of the sound driver.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors/en-usNote In some cases, the manufacturer may instruct you to uninstall the current sound driver and to delete the driver files. To do this, follow the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
Dec 12, 2010 | Toshiba Satellite M35X-S114 Notebook
No audio and sound
Click on START
Your sound playback device (such as Avance AC 97 Audio) should be listed. And there should NOT be a yellow exclamation mark in the left margin (If there is, this is an indication that the device is not working properly - see CORRECTIVE ACTIONS below.
Click on START
In the Sound Playback dialog box your sound device (something like "AC 97 Audio") should be listed. If it is not, click on the pull-down menu and select it if you can..
CORRECTIVE ACTIONS
If the playback device is built into the motherboard, the device may not be enabled in the BIOS. Check your BIOS settings. If your sound device is disabled, enable it and repeat this procedure.
If you do not have built-in sound on your motherboard you will need a sound card installed in an expansion slot on the motherboard. This card may not be present. If there is no sound card, install one and then repeat this procedure.
If you do have a playback device installed and enabled and either you have an error indication, drivers are not installed, or device manager reccommends a driver update, you will have to download drivers from either the motherboard or sound card manufacturer's web site. Also, if the drivers are installed and you no have no error messages, but you do not hear sound when you click the black triangle, you may have a hardware problem on your motherboard or sound card.. At this point, you may want to get some help from a qualified PC technician.
If you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Dec 09, 2010 | Computers & Internet
No audio ouput device installed
Click on START
If a playback dvice is NOT listed se CORRECTIVE ACTIONS below.
Click on START
CORRECTIVE ACTIONS
Regards,
Yavacotech
Dec 08, 2010 | Computers & Internet
My sound sounds like a skipping record. And I had
You Reinstall the driver.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on the Sound, Video and Game Controller then
  • See the Audio Driver is in the list.
  • After this Right Click on the Audio Driver the Click on the Update Driver and update diver wizard will start.
If you want to download HP Sound card Driver. You can download from this site. HP Sound Card
Mar 09, 2010 | HP (153147-001) Sound Card
Digidesign MBox 2 micro doesn't playback sound from windows vista
make sure that windows recognizes it on your hardware devices...right click on My Computer and go to properties...clck on the hardware tab and click on Device Manager....makes sure that all Yellow Exclamation points are resolved and that windows has installed their drivers etc by clicking on them and updating driver...you may need to specify the location of the drivers whether they are on disk or on your computer somewhere...after this is done...try going back into the sound properties and seeing if the newly installed device is coming up...
Apr 08, 2009 | Computers & Internet
Playback on audio cd's sounds bad. Sounds scratchy.
I would always install the driver first , especially if they have an updated version since your last install. also might check if there is a direct connect line attches from the back of the cd rom to the soundcard or motherboard. sound newer motherboards handle sound better without these.
Apr 04, 2009 | HP Pavilion 521n PC Desktop
Sony VAIO VGN-FS840/W Notebook Logo
114 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
