Question about Creative Labs ZEN Vision:M Digital Media Player
Vision: M won't charge
Creative Zen Vision:M won't charge When plugged in to computer, blue light flashes but unit won't turn on. When plugged in to A/C power, blue light flashes, can see battery icon, will turn on. Is this a battery problem or a motherboard problem?
  • NewsLab DC May 11, 2009
    Thanks, but I should have mentioned that I already tried resetting. Didn't help. Any other ideas?
The battery not charging,
I hat the same probleam. Solution reset the unit while is plugged on the Ac charge, turn off and on. will work.
ciao Enzo
Posted on May 11, 2009
How do you even rest it while plugged in? the charger is in the way
Posted on Jul 08, 2009
How to open its back because i change its battrey!!!!!!!!
Posted on Apr 30, 2011
    Problem Solver:
  • 8 Answers
MrKicco com, thanks a mill, it did work!!!
No need to use the reset hole, just plug into AC and this troubleshoot screen will come up... there you can select Clean up / Format / Update firmware / Reboot! I tried the reboot option and the player proceeded to rebuilding as it should have done with reset, then worked normally!
Thanks again!
Posted on Aug 19, 2009
It worked thanks man!
Posted on May 15, 2009
Zen Vision M 30Gb Mp3 player wont turn on
remove the battery, if you let the battery connecters hit the terminal a few times it works a a manual reset it works with almost anything
Jul 20, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
I had a similar problem with my Zen Vision:M, whereby the computer just stopped recognizing my device. I found out it was because Windws has updated to Service Pack 3 automatically, and for some reason my player only works with SP2. It started working again when I installed SP2 again, but then I keep getting the annoying upgdate notifications from windows.
May 27, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen connected to my computer but i can't explore it
I recently charged my friends zen for him and the power was run down, the blue light u see is normal it is just recharging, just wait for about 20-30 minutes for it to charge a little and turn the power on, it will still charge.
Mar 17, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen just flashes
have you tried to charge it using an ac charger?
May 19, 2008 | Creative Labs ZEN Vision:M Digital Media...
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision won't turn on
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Wont turn on
Keep charging it, that's what happens at the initial charge stage. It will take maybe 24 hours to charge and then will turn on fine.
Jan 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision m
Zen V is dead
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
489 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
