Question about RCA H5450RE3 Accessory Handset For -25450 Phone
RCA 25450RE3 - Incoming Call Ringer Setting
Is there a way to stop certain extensions from ringing for incoming calls?  Our phone system is a RCA 25450RE3.  We have 8 handsets and I would like only one of them to ring with the base unit when there is an incoming call.  I have tried to turn the handset ringers off, but then they remain of for intercom calls as well.
  • 2 more comments
  • wookie_lhs Oct 16, 2007
    Thank you for the suggestion.  When I turned the volume down, the handsets still rang with every incoming call.  When I turned the volume on the handsets off, even the intercom calls were silent.
  • Anonymous Mar 18, 2014
    Both the base set and handset read registration complete but then the handset goes back to display press reg. to initiate registration. What am I doing wrong?
  • Anonymous Mar 19, 2014
    unable to receive incoming calls, ringer rings once then cuts off
  • Anonymous Mar 27, 2014
    Incoming call is automatically placed on hold and does not ring through to specified extension
    Problem Solver:
  • 7 Answers
Try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Posted on Oct 12, 2007
How to stop / edit all incoming calls ringing to other 2 extensions at the same time?
What phone system are you using?
I will gladly show you how
KX-TEA/TES/TA series or KX-TDA/TDE/NCP series
Oct 25, 2015 | Panasonic KX-T7633 Corded Phone
How do I turn the ringer off at my phone for external incoming calls?
Go into the extension programming and change the line settings to no ring. It is best done if you have a display phone so you can see the changes. If not, then you will need to look at the flashing line lights when you enter the programming mode.
Press Feature 00. This will take you into the programming mode. You should see the line buttons lit up green. They will be Solid (Immediate Ring) or Slow Flash (Delayed Ring) or Fast Flash (No Ring). I assume yours is solid so push each line button until it changes to a fast flash. Once done press Feature 00 to exit the system and save the settings.
Sep 11, 2014 | Avaya Lands Phones
Incoming ring
Make sure the ringer is turned on on the extension. There should be a small switch either on the handset or the base that controls it. Also in the menu there could be a setting for the volume that needs to be set.
Apr 11, 2014 | NEC Lands Phones
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
Ringer rings continously without pausing when receiving an incoming call
My phone no longer does the rhythmic vibration for incoming calls. I used to have it set up to vibration type 2 (where it vibrates in a certain pattern). However, as of last night, any incoming call just vibrates regularly instead of in a pattern. I checked to make sure that the setting was not changed, and everything looked ok. Is there a registry edit I can do to change this? I would rather not hard reset my phone, but I will have to do that if there's no other way. Thanks
Aug 11, 2010 | Vtech CS6219 Cordless Phone
M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
Simply want to turn ringer off at my phone for external incoming calls
How do you want to be notified? How do you determine if a call is for you? Does an operator answer the call and transfer it to your extension? If so, you just need to change programming for your phone so it does not ring for incoming calls. It would still ring if a call is transfered to you. Programming is changed in the phone system, not the telephone. Your phone can be used on different Nortel systems that program differently so you need to find out which system you have and locate the manual for that or pay a local installation company to make the changes.
Nov 08, 2007 | NorStar T7316E Corded Phone
Lands Phones Logo
643 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
