Question about kawasaki Full Suspension Mountain Bike Men
My kawasaki 400 bayou runs but doesnt have enough power that it u
I put a new air filter and put new oil in it and a spark plug but it still doesnt work well
I found all spark plugs do not work well in the Bayou, especially NGK....try a champiion spark plug..it may fix the problem.
My Bayou use to stall all the time with the NGK spark plug, but runs good with the Champion spark plug.
Posted on May 12, 2009
2002 Kawasaki bayou klf300 4x4 missies at half to full throttle cleaned the carb and bought new cdi,rectifier still misses
Hi, Ellis and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.kawasakimotorcycle.org/forum/mechanics-corner/35765-89-bayou-300-backfires-coughs-above-idle-speed.html
Kawasaki carb problem Gurus please help
https://www.tradebit.com/filedetail.php/118245427-kawasaki-bayou-300-service-manual-repair-1986-2006
May 01, 2016 | kawasaki Motorcycles
Why is my 93 kawasaki bayou 300 losing power.. Cleaned carb and made it worse.. Did compression test 150psi
Check the air filter and the entrance TO the air filter. Perhaps you put a rag or a sponge there for safe keeping? I did that on a Kawasaki H1-500.
Check the fuel supply is good, faulty tap, blocked filter etc causing fuel starvation. Check spark plugs for cleanliness and gap.
Mar 30, 2016 | kawasaki Motorcycles
What list of things that control my neutral light from coming on for my kawasaki bayou 220
Bayou 220 250 KLF220 KLF250 Kawasaki Service Manual ...
www.cyclepedia.com/...manuals/kawasaki...manuals/kawasaki-klf250-ba...
The Kawasaki KLF220/250 Bayou requires the valve clearance, engine oil and oil filter be inspected every 600 miles. Keep your Bayou free of problems and in ..
Aug 05, 2015 | kawasaki Motorcycles
My 1995 Kawasaki bayou 300 will not start it has a spark gas to the Carb and a new battery it cranks and cranks but will not start. How do I get it to start someone please help I wanna go riding..
Hi Abbott:
You've gotta be close. Let's double check.
- Pull the plug(s) and make sure they're not fouled and that there is a nice hor blue spark across the electrode.
- Fresh gas in the tank
- flush the carb (drain plug)
- Fuel filter if there is one.
- Clean the air filter.
Put it back together and give it a try. If it runs, great, if not, pull a spark plug and see if it is "wet" with gas. If not, the problem will probably be with gummy bad stuff in the carb. Take it off, and an air hose to try to blow out all the little passages.
Keep smiling, you'll be killing bugs in no time!
Apr 22, 2015 | kawasaki Motorcycles
Adjust idle
!. New spark plug
2. New or CLEAN air filter
3. CLEAN and properly set carb.
4. Air screw should be about 2 turns out AFTER lightly seating.
5. Adjust idle speed to your liking, but not too high.
6. Refinement is made with 1/4 turns of the air screw.
Jul 08, 2014 | ATVs
Kawasaki 300 bayou not running smooth
May be water in the gas or your spark plug may be misfiring and also the air filter may need replacement or cleaned out..Hope this helps!
Oct 23, 2013 | kawasaki 2004 Bayou 300 4x4
I have a 2006 Kawasaki Bayou 250 it is always fowling spark
does it backfire when revving down? are your spark plugs coming out black? if yes, you need to lean out your system a little by adjusting the mixture screw on the carb.
May 13, 2010 | Motorcycles
Take the carb back off and adjust the float in bowl to spec.If you don't have spec just adjust till fuel stops overfowing an go with that.Yeah, it might take a few times.
Mar 21, 2010 | 2006 kawasaki KLX 250
I need to know the amount of oil to put into a bayou 220 atv
When you filled with new oil, if you changed the oil filter, and the oil was at the top third of the inspection window after you started it and then shut it off, the oil level is correct. When you start the engine the oil is being pumped to the top of the engine and through all of the oil passages. That is why you can not see oil in the inspection window while it is running. Make sure when you are checking the oil through the inspection window the vehicle is on a level surface and you have allowed enough time for all of the oil to drain back to the crankcase.
Mar 22, 2009 | 2003 kawasaki KDX 220 R
No spark wont start
Hey i had a similar problem a liitle while ago on my yamaha,i disconnected the kill switch wire then i had spark(faulty kill switch)
Woth a try,cheers, Alan.
Jan 12, 2009 | kawasaki Full Suspension Mountain Bike Men
kawasaki Full Suspension Mountain Bike Men Logo
521 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
