Question about Sony KV-36FS16 36" TV
Red color problem
Screen turns slightly red and darkens somewhat. Problem has been intermittent with a short duration but has now become solid. Tried adjusting the Video Menu controls including resetting each Picture Mode to its default settings. No help. Any ideas of what the problem cause may be? I.E. picture tube, circuit board, etc. I would like to determine whether it is worth repairing or should I use it as a boat anchor.
    Habit-Forming:
  • 188 Answers
Dear mr newk
i study ur problem carefully i got that u have a big problem....
i have a solution of u r problem...
actully u have problem with u r circuit board...ok
there is a colour code ic which is responsible for all colour effect on ur telivision.
u r colour ic is not working properly...
just u have to do is to change ur colour ic on ur circuit board..
i m 100% sure that u r problem will be solved...
best regards & best of luck..
Posted on Oct 12, 2007
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
60p8342a philips tv picture looks red sound is fine
go to a unused video input and turn color off----screen there should not be red or even somewhat red, if it is the red screen control may have to be lowered just slightly.
Dec 04, 2012 | Televison & Video
I have a sony kp-53n77 rear projection tv i cleaned the lenses but i still have alittle to much red how can i clean up the color
Older projection set:
Not knowing exactly what it looks like I suggest two things: first in the menu look for convergence to see if it is off adjustment wise--it can be adjusted in customer mode to see if that helps.
Also either turn color all the way off (Black and white) to see what color the screen is with no color--if somewhat red you will need to turn the red screen control down--I can tell you where and how.
If screen is too red, red will be the prominent background color with color off or on.
Another easy way to LOOK is go to an unused video input---should only see "Input 1" for example in green and rest of screen should be black and not red to any degree.
Let me know with a comment here what you find.
May 02, 2012 | Sony KP-53N77 TV
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
I have a 2003 F150 Supercrew. About 42,000 miles. Just started to get a slight squealing sound from the rear end of the car when moving from a dead stop. Very intermittant and lasts only for a very short...
Check brake drums for accumulated dust if it has rear drum brakes....have the U-joints checked out and lubed if possible
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 27, 2009 | 2005 Ford F-150
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
May 11, 2009 | Televison & Video
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Screen tinted red
CRT is bad,I just stripped one for re-cycle yesterday.....T.
Oct 12, 2007 | Sony KV-36FS16 36" TV
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Color variation and blinking red light on bottom of tv
The light flashing 5 times is normal at turn on as the set is monitoring current drain on the pictures tube cathodes. Any speakers near the set that have un-shielded magnets could possibly cause color issues.
Apr 16, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-36FS16 36" TV Logo
95 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
