My toshiba 62HM15 is flashing red and green lights on front of tv and doesnot turnes on.
    Brigadier General:
  • 8,619 Answers
Hi
Red and green light blinking means that the lamp is not working properly Turn OFF the TV and then ON again. If the problem persists, you need to replace the lamp unit. Before replacing the lamp you can check to make sure all slots and openings in the TV cabinet are not covered, blocked, or dusty. Please refer to this service manual for how to change the lamp unit.
Toshiba 62HM15 Service Manual
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on May 10, 2009
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
The red light is blinking and the tv want come on
First on this model remove the lamp and examine it to see if shattered inside---customer replaceable and door (unplug set first) is on left side as seen from the front.
With door off remove two brass screws and grasp handle on lamp cartridge and slide it out---with the screws removed the lamp cartridge just slides out--pull it out and look.
Mar 24, 2012 | Toshiba Televison & Video
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Toshiba 62hm15a- bright flashes
my toshiba 62HM15A has bright and dark flashes.
Sep 30, 2008 | Toshiba 62HM15 62" Television
Humming noise & color changes picture flashes from red to green
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
Aug 09, 2008 | Toshiba 62HM95 62" HDTV
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Toshibe CF32G50 - Red Flashing Light
YOUR SET IS TRIPING MAYBE POWER SUPPLY IN TV SET
Jul 11, 2007 | Toshiba CF32G50 32" TV
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
Electro Med Services...
