Question about Refrigerators
KitchenAid Refrigerator Ice Maker not working
Our Kitchen Aid refrigerator is a 25ft side by side Model KSRU25CRSS00. It has stopped making ice. The shut off sensor apprears to be working correctly but the water tray is dry and there is no ice stuck in the cutter or elsewhere. The water dispenser works fine and the filter is still ok. We had several days where the water company had the service to all the homes in our neighborhood shut off while the service the main supply line. It was during this time that the ice maker quit producing.
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
  • 409 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
  • 1218 Answers
SOURCE: Ice maker stopped working
Good day,
A step by step procedure should resolve your problem. If the dispenser is working, you can skip that step.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on May 25, 2010
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
Kitchen Aid KSCS25INSS ice making replenishment rate has been diminishing for about a month. Today it stopped dropping ice completely. The ice tray has frozen cubes which will not fall
There could be many reasons for this problem. Because you said the ice maker stopped with ice in the trays leads me to focus on the ice maker alone. I will try to get some photos and links when I return. Sea Breeze
Oct 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
MY KITCHEN AID KSRP25FNSS ICE MAKER IS NOT WORKING
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
689fr
Jun 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Not making ice
The oil from the compressor has pumped up to the top part because of it only the ice maker s not workind change the lead valve of the compressor which can rectify your problem
Jul 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
332 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
