Question about Garden
How do you tune up a weedeater? Runs rough. When I get it running, I have to keep it full throttle to keep it running or it will die. After 15 min or so it just quits, probably because it get hot.
  • pilotkev May 11, 2009
    jbridger (John)
    Thank you so much for your advise! I went right out the garage and followed your directions, mainly with the idle air and main air mixture adjustments. It cranked right up and I tinkered with them a little till it ran smooth and went out and finished the job. The homelite did not quit once!
    I have never been on this website till yesterday. Now I know where to go when I am stumped!
    Thanks again,
    Kevin
    pilotkev@gmail.com
  • 246 Answers
Hello:
Does the Spark Plug Fire when the Engine Quits after 15 Minutes?
If No, then the Ign Module/Coil is Bad and Requires Replacing.
1- Clean the Exhaust Port and Muffler of Carbon.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>If the Exhaust Port and Muffler are Clear, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • John C Bridgers Sr May 11, 2009
    Hello Again Kevin:
    I am Glad I was Able to Assist.
    >>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
Run for 15 min then dies. It was low on oil. Added oil over the full line now it runs for 3 min running rough and then dies To much oil now?
Your mower dying would have no correlation with how much oil you have in the engine. Didn't I answer this question for you yesterday?
Your problem is fuel related. Fuel goes off, so it should be fresh from the gas station every season. Check lines for kinks. Check lines for air locks. Check your fuel filter if you have one. Check that the fuel tap works properly.
Apr 03, 2016 | Garden
'87 Yamaha ProV 50: Will cold start and idle well. After a full throttle 1-2 min run will begin & continue running very rough near idle. Will die without addtl throttle imput.
Hi Roderick:
I'm not familiar with your engine configuration, but on some of the older bikes, vibration eventually can cause a wire to break in the coil. When the engine is cold, the wires make contact and it runs, but as soon as it gets hot, the connection is broken or compromised and the spark quits or drives you crazy.
Since your bike runs when cold and quits when hot, I'd be looking for electrical rather than fuel problems.
Hope this helps.
Sep 09, 2015 | Yamaha Motorcycles
My Zoom 50 dies after mowing about 15 min. Why??
How does it idle? Rough or how it is supposed too. From the information you provided, it would suggest a problem in the fuel system, or the linkage to the throttle control.
Could be overheating, could be a safety device malfunctioning. Check oil, air cleaner, fuel filter, and plugs. How many hours are on it?
Mar 26, 2014 | Ariens Garden
Have 82 ford truck f150 runs for abut 5-15 mins than dies getin gas chang full pups two times same thant runs and die
Hmmm...maybe piston ring failure, valve seal failure, rich air/fuel mixture or maybe a head gasket (however that is normally white smoke due to coolant burning instead of oil). If it's so dark that it's almost blue then I can tell you that somehow oil is getting into the cylinder and burning alongside the air and fuel. Your best case scenario is that the engine is running rich (Rich:Too much fuel, Lean:Too much air) and the smoke is a dark grey to black color. CAUSES OF SMOKE
Dec 28, 2012 | Ford Cars & Trucks
Out the box.Cranks and runs on cold.when you give it full throttle and knock it off fast idel try to let it idel it die's.After u use it a few min. it die's and want start back till it cools.
This is a common problem out of the box for weedeater products. This simply needs a carb adjustment which is not something the consumer can do (requires a special tool), You will need to take this to a weedeater dealer near you to get it done, it's covered under the warranty.
Jul 21, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Runs rough like missing
check the fuel pressure when it is idling for about the time it takes to die see if it drops.most likely gonna need a fuel pump
Jun 22, 2009 | 1999 Oldsmobile Silhouette
Rough idle 2 cycle outboard
sounds like u need to do a tune up on it. clean the carb, new plug
Nov 17, 2008 | Sport & Outdoor - Others
Garden Logo
5,045 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
