Question about Mtd 22" Yard Machine Push Mower
What the coil is supose to spin is not spinning
Im trying to fix my push mower the recoil will noy come out i thaught that might be the problem so i removerd it the recoil is fine but what thats supose to turn is my problem, sorry i don't know what its called it's not seized it will turn backwards but it gets gamed at the same spot going forwards and i can't see what causing it
  • Dwain Pippen May 11, 2010
    Did you check underneath to see if the deck is bent and the blade is hitting a spot?
  • Anthony McFarland
    Anthony McFarland May 11, 2010
    Is the handle all the way up and are you holding down the bar on the handle when attempting to pull the cord?
Has a bolt screw or something dropped inside cowling and stuck to magnet on flywheel
Posted on May 20, 2009
The recoil rope works when it off the engine, however, when it is attached to the engine, it does not recoil like it should.
Sounds like you have a weak spring that needs tightening up on the recoil or the things that spin are catching on something. I feel its the spring that needs rewinding to make it stronger to work. To do this you need to take the recoil off the engine.
Apr 12, 2015 | Garden
What to do when craftsman mower pull cord won't recoil?
Sounds like the spring inside the recoil has either broken or let go so it won't recoil. If you are lucky it could be the wheel that the cord goes on is seized or stuck. You can take the recoil off most mowers by taking out two or three screws and lifting it off the engine. They can be repaired but it takes time having to be careful the spring won't spin and hurt you. I have even taken a recoil off another engine and if the holes for the little screws don't line up just drill little holes beside the old ones and reinstall the little screws.
I even used a 18 volt cordless drill to crank the engine using the bolt on the fly wheel and the right size socket. Leaving the recoil off You have an electric start that way.
Aug 30, 2014 | Craftsman 21" 190cc Rear Bag High Wheel...
To much slack in pull cord on poulan pro push lawn mower
u need to remove the recoil assbly and restring.remove recoil and cut not out of string.remove line.rotat the coil assbley counter clockwish till spring presser is tight.hold it in place and reinstall cord threw eye whole tie new not and let off recoil slow.slack should go away.
Aug 19, 2013 | Poulan Pro PR550N22SH 22Inch Briggs ...
Recently, the rope recoil mechanism on my lawnboy mower would not recoil completely or not at all. I removed the complete recoil assembly and the rope in order to rewind the coil, which appeared to be...
Im sorry but it sounds like the spring has broken. So I am not that familiar with Lawnboy but some rewinder are not serviceable and the whole housing has to be replaced .
Oct 22, 2009 | Garden
I hit a rock and bent the blade on a yard machine. Replaced the blade and tried to start the mower, but the start rope doesn't come out all the way and recoils hard as I'm trying to pull it out.
I did the same exact thing over the weekend, try adjusting your new blade unscrew the main bolt to the blade about 1/2 turn that should get it spinning again, same exact thing happened to me. Good Luck
May 17, 2009 | Mtd 22" Yard Machine Push Mower
Have a recoil pull start mower that won't recoil
the starter clutch probably needs cleaning. It is located right on top of the fly wheel. Pull the the pull rope housing off and you can see it
Apr 04, 2009 | Poulan "" Push Mower
Toro Mower Recoil Assembly
try turning it clockwise. if it doesnt work it means the inner coil may be broken. its pretty difficult to fix those but if you would to try let me know and i'll talk you through it
Sep 20, 2008 | Toro Lawn Mower With Toro Power Tools
Mtd 22" Yard Machine Push Mower Logo
111 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
