Question about Cameras
Mode dial will no tturn properly
My DMC FX 07 Panosonic Lumix mode dial will not turn properly. Cannot take photos, but turn off and on. Can also display photos. What's up? markham_dennis@yahoo.com
  • 98 Answers
Probably the connection between the top dial assy and the mainboard of the camera is loose, you can open the backcover easely and push the top operation to the mainprint and clsoe the backcover with the screws.
Posted on May 10, 2009
I have a Lumix DMC-LC50 When I turn it on it says: Mode dial is not in the proper position I tried everything
The mode dial is the knurled knob on the top of the camera - if you didn't already know. This same error message displayed when the knob is between selection. If you have moved the know to a valid position - where it stops in a detent, the message should clear from the display and be able to take pictures.
If moving the mode dial so that it rests in a detent and the message is still displayed, it indicates a problem with the switch inside the camera (that is operated when the mode dial is rotated). This is not a user serviceable part, and should be professionally repaired. I found United Camera to list a Mode Dial repair to be $42. there are plenty of others that can make this repair for you, too - this was simply the first I saw that had a price (I have never done business with nor am I affiliated with United Camera in any way).
I hope this is a good starting point for you & good luck. Please rate my reply - thanks.
Jun 10, 2011 | Panasonic Lumix DMC-FZ18 Digital Camera
i had the same problem try this tap the outside of the dial lightly while turning the camera on it should basically "pop" right out if it didn't work it needs to go to a panasonic service technician. most likely the lens is damaged and the mode switch
Feb 13, 2011 | Panasonic Lumix DMC-FX30 Digital Camera
Lumix camera says mode dial is not in proper position
Hi and welcome to FixYa!
Please try to remove the battery and let it sit for atleast 5mins. then reconnect it again. This should reset the system and can resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
Dec 21, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
When you turn it on the screen displays "mode dial in not in the proper position." Mode dial does not turn properly.
Something seems to be broken or off between the mode dial and the switch. It also may have broken internal parts.
I have had a camera with a similar problem. It was that the small switch inside was broken, and could not be repaired.
These mode switches can be changed, but will require a digital camera repairman to do such a job. It also could be sold for parts/repair on a site such as Ebay.
Aug 31, 2009 | Panasonic Lumix DMC-FX100 Digital Camera
CAMERA UNIT IS PANASONIC LUMIX DMC-FX33 MENU
It may be that for the type of picture you are taking the mode - dial at the top of the camera is not compatible.
Try a couple of different modes by adjusting the dial to auto, etc.
Apr 22, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Panasonic DMC-TZ1 operates in Playback mode only
The position from the dial wheel is not corresponding with the electrical position. If you can do it by yourself you can adjust it and tighten the midscrew from the dialwheel
Regards, Rob NL
Apr 20, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
MODE DIAL IS NOT IN PROPER POSITION
Try turning the mode dial again. It may not have been turned properly.
Jun 13, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
how to take good pic beside use the iso mode
May 19, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
Cameras Logo
80 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
