Question about Mtd 22" Yard Machine Push Mower
Im trying to fix my push mower the recoil will noy come out i thaught that might be the problem so i removerd it the recoil is fine but what thats supose to turn is my problem, sorry i don't know what its called it's not seized it will turn backwards but it gets gamed at the same spot going forwards and i can't see what causing it
What is this solution?
Posted on May 25, 2009
Why does my recoil not rewind
Probably have a broken rewind spring
Jan 30, 2016 | Garden
My mower will not start
Did you check the cable that is attached to the arm that moves the blade up and down? If something is wrong with it, the mower won't start. My Aunt almost gave her mower away and that is all that was wrong with it. Even though you might think the blade is fully up, something might be wrong with it.
Sep 29, 2014 | Craftsman Garden
I have Scott Bonnar lawn mower and when I try to start it by pulling the cable, the cable does not retract back. How do I fix this?
Sounds like the recoil spring is broken or come un hooked., You have to remove the recoil and may have to purchase a new spring or I have found a lot of lawn mower engines have the same type of recoil that will fit each other. If you can find a junker that the recoil works take the brocken one off and replace it with a good used one. I have replaced many this way.
Sep 24, 2014 | Garden
Husqvarna 6021p push mower. How can I get the rope to recoil?
if it wont rewind you have to remove the recoil that retracts the rope replace it or repair it
May 19, 2012 | Husqvarna 675 hp 21" Honda Rear Bag Push...
Pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Apr 28, 2010 | Mtd 22" Yard Machine Push Mower
I hit a big rock with my walk behind lawn mower and now it sounds really bad when it is running. Whats is wrong with it?
the flywheel key is broken.take the recoil cover off.take the nut off that holds the flywheel on.thake a hammer and lightly hit the flywheel oppisit side of key way.the fly wheel will come off.replace the key.replace the flywheel.replace the recoil cover and test run the mower.should be fine.let me know if this helped................
Jun 29, 2009 | Mtd 22" Yard Machine Push Mower
What the coil is supose to spin is not spinning
has a bolt screw or something dropped inside cowling and stuck to magnet on flywheel
May 10, 2009 | Mtd 22" Yard Machine Push Mower
Have a recoil pull start mower that won't recoil
the starter clutch probably needs cleaning. It is located right on top of the fly wheel. Pull the the pull rope housing off and you can see it
Apr 04, 2009 | Poulan "" Push Mower
Mtd 22" Yard Machine Push Mower Logo
295 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
