Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman riding lawn mower...engine dies when blade is engaged
Runs good, when I engaged the blade the engine died...tractor was in neutral while I was trying to engage the blades...now it will not turn over at all....just had a new coil wire put in it.
  • mehiggs12 May 24, 2009
    I got a new battery thinking that was probably my problem, came home with in installed still nothing. so i a adjusted the safety shut off under the seat and it cranked right up. waited until the next day when i was ready to mow started right up backed out drove about 10 ft kicked the blades on and it died and i can't get it to start again. not sure what to do to it now could the safety shut off under the seat need replacing?
  • 1,000 Answers
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
  • 1 more comment
  • vincent collette Jun 26, 2013
    yes like I said it runs good in all grears but when try to ingage blades it stops runing
  • thomas f crider jr Aug 31, 2013
    i have the same thing going on. Please help!
  • Thomas Sep 11, 2015
    I have the same problem, does anyone know what the problem is?
Check to see if mower deck pulleys turn freely if not then replace bearings or pulleys
Posted on Jun 12, 2012
Try installing a new spark plug. I had the same problem and it help.
Posted on Nov 22, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
What causes a riding mower to die when engaging the blade
safety switch in the seat and in the brake. if one of those is open, engine will die when you engage the blades. Owners manual should have wiring diagram so you can bypass switches to test (if you have brake applied and are sitting in the seat and that is when it is dying).
May 04, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Dies when try to engage blade
there is a switch underneath seat that shuts blades off if not pushed down or there is another one on the reverse that shuts off blades off when mowing one could have went bad hope it helps
Apr 16, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
My craftsman lawnmower dies when i let out on the clutch
make sure your not in reverse with the blades on. if so turn the key left to mow in reverse mode. else check pullies.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
2,468 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
