Question about Nintendo DS Lite Console
Little black latch on ds lite
Am taking ds lite apart because i need to replace case
am following written and video instructions
having trouble with display cables it says to lift little black latch with two finger nails
doesn't show exactly how in written instructions and on video the guys hands cover what hes doing
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • Nintendo Expert
  • 127 Answers
If you are talking about the latch for the top screen flexible cable, here I put some examples about these type of connectors:
As you can see the black or brown latches are there to press the flexible cable contacts down to the connector contacts and avoid the flexible cable to unplug accidentally.  All you need to do is lift the latch and then the flexible will be free to take it out.
In the case of the other black wires, you just need to lift the plated connectors.
I recommend you to roll up the flexible cable and use tape to avoid damage to it when taking it throught the hinge. Thats because if you damage the cable then you must but a complette new top screen because the flexible is soldered directly to the LCD screen.
Good luck...
Posted on Oct 14, 2007
SOURCE:
My ds lite will play gameboy games but not ds games
Your DS cartridge reader is faulty. Unless you know how to take the DS apart and replace the reader by soldering, you should just buy a new one.
Feb 01, 2014 | Nintendo DS Lite
Baby oil in nintendo ds touch screen
Hi, you will most probably need to replace touch screen. Buy new 1 from ebay about 2 quid and a tri-wing screwdriver to take apart console. Youtube videos how to replace touch screen and follow video step by step. Not at all hard to do just make sure you don't break the black clip off the board that holds the ribbon cable for the touch screen, can be write fiddly. Magnifying glass will help and small tweezers.
Enjoy
Jul 21, 2012 | Nintendo DS Lite Console
When you turn on the ds lite the screen just flashes and then turns off
The screen that doesn't flash is faulty and will need replacing, i would suggest you do 1 of 3 things:
1) send it in to nintendo if undr warranty.
2) Take it to a local repair place.
3) Replace the screen yourself.
To replace the screen yourself you will need take the console apart. The screens can be brought from vrious sites such as ebay for a reasonable cost.
If you need help to repace the screen click on my name and look at the repair guides i have written.
Regards,
SOD69
Apr 05, 2010 | Nintendo DS Lite Console
My daughter's ds keeps displaying the message, there is no ds card inserted. we've tried every game she has, turning it off and on, blowing in it...help
Chances are the pins in the slot are bent or broken...To check shine a torch/ flashlight down the slot and see if anything looks out of place.
My best suggestions for resolving this are:
1) If under warranty then send it off to them for repair.
2) Find a local repair place and give it to them to repair it.
3) If you have good soldering skills and fancy a bit of DIY repair you can have a go at sorting it yourself.
To be honest its far easier to just replace the entire slot-1 part than it is to take the part apart and repair it, the cost of the slot- 1 is very reasonable from ebay.
I have a few guides written up to help you if you do decide to take the DIY option, they are as follows:
DS lite slot- 1 replacement
DS lite dismantle guide
Hope this helps, any further help or advice you may need then feel free to contact me.
Regards,
SOD69
Mar 13, 2010 | Nintendo DS Lite Console
DS Lite no longer recognizes games when they are inserted
My best suggestions for resolving the bent/ broken slot-1 pins are:
DS lite slot-1 replacement guide
Regards,
SOD69
Bottom screen on nintendo ds not working
Could be an LCD failure or a loose ribbon connection. You will need to take the DS apart to check either.
Feb 28, 2010 | Nintendo DS Lite Console
DS lite plays some games but not others.
Chances are its the slot- 1... Have a look at my guide i've written to see if any of the tips I suggest help, if not there is a bit on replacing the slot- 1 part. I also have a guide on taking apart the DS lite if you need it. The replacement part is readily avaliable on ebay for very little money and so long as you have soldering equipment and a steady hand you should be fine.
Slot- 1 Trouble shoot guide
If you need any more help or have any questions please feel free to contact me via my profile page.
Regards.
SOD69
Feb 14, 2010 | Nintendo DS Lite Console
My DS wont turn on so I try to charge it the orange light comes on but eventually it turns off an suggestions?
When you say it doesn't turn on does the green light come on at all?
If the green light stays on for 1-2secs then you should see one of the screens flash, if that happens then you will need to replace the screen that doesn't flash. If you need to replace the top screen follow this guide, or if you need to replace the bottom screen follow this guide.
If there is no green light at all then the chances are the "F2" fuse has blown. To replace the fuse follow this guide.
If you need help taking the DS lite apart follow this guide.
The guides are written by me so if you need any extra help or if you have any more questions don't hesitate to contact me.
Hope tis helps.
Regards,
SOD69
Feb 11, 2010 | Nintendo DS Lite Console
My ds lite touch screen works in some areas but not in the middle do i need it replacing
Try to calibrate the screen again and if that doesn't work then chances are you will need to replace it.
If its under warranty then send it off, if not you can either take it to a repair shop or do it yourself.
If you do want to do it yourself I would suggest trying disconnecting the touchscreen and then reconnecting it before you go ahead a buy a new one just incase its the connection thats wormed its way loose.
If you need a guide for how to take the DS lite apart including what tools you will need I have one written up on here.
Dismantling A DS Lite
Feel free to message me if you need any help.
Regards,
SOD69
Feb 09, 2010 | Nintendo DS Lite Console
Nintendo ds lite that shuts off unexpectedly
Hi again,
Ive been doing a bit of research and it seems that if the DS lite has had a knock the black coil near the power switch could have been knocked loose which would make the DS lite switch off randomly. If you want to see if thats the problem take the DS lite apart (for a dismantle guide click here) and check to see if its loose... its the black round thing with 100 written on it near the power switch. If its loose then heat up the solder round it and that should reset it.
If thats not it check the L2 transistor is firmly in place, again if its loose heat the solder and reset it.
Another thing you can check is the power switch make sure its solid and doesnt wobble internally i.e. the black moveable part only moves the way its supposed to, as well as checking the solder is solid.
Hope this helps, if it doesn't sort out your issue then get back to me and I will continue to help you.
Regards,
SOD69
Jan 04, 2010 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
80 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
