No Picture No sound Green light on front
No Picture No Sound, Green light on front Proview RX 326 3200
  • 119 Answers
SOURCE: Sony KP-51HW40 No Picture, only sound
how many thimes does the light blink, it's an indication as to where you should start looking for the cause of the problem
Posted on Dec 21, 2006
  • 12 Answers
SOURCE: press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Posted on Apr 15, 2009
  • 80 Answers
SOURCE: loose picture and sound for 40 sec. then picture and sound return
The lamp is going bad.
Posted on May 21, 2009
rulds2008
  • 3866 Answers
SOURCE: no picture or sound
This would start with the power supply on up to the conv. board.. I have seen som many TV's like this wiht problems.
Posted on May 24, 2009
ladywinn
  • 5138 Answers
SOURCE: rca hd52w59 chirping sound and light 3 times no picture
on deflection board it will be the bottom left board Behind FBT flyback transformer there is 2 transistors but are diodes # DL030 and DL032 ck them one is shorted keeping high voltage from coming up.
Posted on Sep 25, 2009
The green light comes on but the tv dont come on
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Dec 30, 2015 | Proview Televison & Video
How to fix a proview 3200 HD TV with no sound?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 10, 2014 | Proview Televison & Video
My Proview RX-326 lcd tv Has sound & picture but Picture mix colers brite
There is some incompatibility issue. Did you check the format is set correctly for PAL/SECAM etc.?
Jul 28, 2012 | Proview PA-32JK1A 32 in. LCD Television
32inch proview lcd tv has a green square instead of a picture,but i get the sound .?
if you are getting color on the screen, chances are that you might have a cable loose. I'm not sure if you are using component cables but sometimes when the blue cable is loose, it will cause a green screen. or if you are trying to watch something above your TV's capabilities, this will happen as well.
May 04, 2010 | Proview HX303 30 in. HD-Ready LCD...
No picture but there is sound
This may be the problem click on your remote source button and see what is checked on the blue sceen that pops up...it may be on the wrong setting... I hope this helps, Ken, Attica, NY
Nov 24, 2008 | Proview PA-32JK1A 32 in. LCD Television
Green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
May 27, 2008 | Proview PA-32JK1A 32 in. LCD Television
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
Electro Med Services...
