Question about LG Flatron L1750S 17" LCD Monitor
Calibration Hi, I'm temporarily using the L1750S for working with design softwares (Illustrator, Photoshop, etc). However the colors and contrast on my screen are way too vivid (an eyesore to be precise). Apart from the default settings, is there a way to optimise the display settings?
  • ajay30 Oct 18, 2007
    Yes, I've tried adobe gamma but it does'nt help. Gamma tells me to turn my contrast way up and then adjust the grays. This turns my monitor into an even bigger eyesore. It does'nt work the way i normally do it on a CRT.
Have you tried adjusting the "Adobe Gamma" via the setup from your control panel?
Posted on Oct 18, 2007
How do i use adobe illustrator
u can create design in Photoshop and then switch through
path to illustrator
Oct 11, 2014 | Adobe Illustrator CS2 for PC
Recommend designer software and their advantages and disadvantage
Adobe Illustrator and Adobe Photoshop. They are the standard of the industry. Don't spend your money on anything less. Both can be purchased together in the Creative Suite package. Illustrator allows you to creat pixel and vector based artwork. Photoshop allows you to edit pixel based images.
Aug 17, 2009 | Software Imaging Compuworks Design Shop...
I bought the PC version of Illustrator in 2007 with the CS3 design premium package. In March of this year both Illustrator and Photoshop stopped working. They both load like normal, but whenever I try to...
I found that ZoneAlarm was inadvertently blocking it. I had to completely uninstall the service and then reinstall the latest version again. Now everything is working just as it should.
Jun 26, 2009 | Adobe Illustrator CS V11.0 for PC
I hava a full version of Adobe Photoshop CS2, Adobe Illustrator
buy the full version then you will recieve a serial with it
Apr 22, 2009 | Adobe Illustrator CS2 for PC
Which product to use for web designing and graphic designing
Hi. You can use Adobe Dreamweaver for web designing and Adobe Photoshop and Illustrator for graphic designing. Use their latest version which is CS4.
Apr 13, 2009 | Adobe Computers & Internet
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
image ready is basically a web desing program for designing web pages and web base graphics GIF'S etc
Nov 03, 2007 | Adobe Photoshop CS2 for PC
Flash File Overall Color and Contrast too light
Sep 26, 2007 | Macromedia Flash MX
LG Flatron L1750S 17" LCD Monitor Logo
327 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
