Question about Microwave Ovens
Opened door with nine seconds still in cooking mode---that is where it sets today.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. By reading the issue it seems that your Microwave is stuck in cooking mode so you need to reset the microwave so that it can come out of that mode. If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on May 10, 2009
How do I know wattage for 1974 recipes and convert cooking time to todays microwave (1200)
A 1974 Microwave Oven is probably not putting out more than 600 watts. You need to do a power test to determine it's actual power output. Place a 2 cup glass measuring cup with exactly 500 mL of cold water. Record the starting temperature of the water. Run the microwave on 100% power for 18 seconds, using a watch or timer, not the timer on the unit. Take the water out and stir it to make sure that there are no hot or cold spots in the measuring cup. Record the new temperature. Example: 78.4-64.1= 14.3.
Multiply 14.3 X 38.75= 554.125. The power output is 554 watts IEC. If the recipe is set for a 1200 watt unit, and your is almost 600 watts, obviously, you would double the cook time. Since this is rough, you need to experiment a bit. If the cook time is 10 minutes, check your product at 8 minutes. Be sure to push the stop button before you open the door when it is in cook mode. This will save wear and tear on door switches and leave the remaining cook time on the timer. Let me know how this works out for you..
Oct 11, 2013 | Panasonic 1974 Microwave Oven Cookbook &...
It only cooks for 59 seconds and then stops and I have to keep pushing stop every 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp (and Sharp-made Dacor and Wolf) models stop after 59 seconds.
See the sample drawing for a typical damper assembly. http://www.fixya.com/uploads/Howto/B27054B.jpg
We have the applicable service manuals here and here.
You can order Dacor parts by part number from Encompass here.
Sep 13, 2010 | Dacor DMT2420SS Microwave Oven
Machine turns off after 59 seconds despite what time or power is set. plrase help!
Sharp (and Sharp-made Dacor / Wolf) models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manual here and the parts list here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Aug 15, 2010 | Dacor PMOR30SS Microwave Oven
Sharp model R-1870 Carosel quits cooking at 59 seconds
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
Jan 26, 2009 | Sharp R-1480 Microwave Oven
Microwave/convection oven quits at 59 seconds
This is a common problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
Our sharp 957 will now only microwave for 59 seconds then stops and rattles for thirty seconds. The convection option stopped working ages ago. Any ideas please?
This is also likely why your convection mode stopped working.
Info on ordering Sharp UK parts / spares is here.
Sep 27, 2008 | Sharp Microwave Ovens
Help please
Are you saying that it will stop cooking after 59 seconds, but it will resume cooking if you press Start again?
(If not, please reply back and clarify)
If so, this is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
Aug 04, 2008 | Microwave Ovens
R957 cooks for 59 seconds then stops ,resumes for 59 seconds if cook /start pressed all cooking modes affected kitchen timer works ok
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 31, 2008 | Microwave Ovens
I have a sharp r959slm microwave. what ever time you set whether convection or normal it cuts out after 59 seconds. It makes a noise simular to coggs turning. is it something i can tackle or not
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 08, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
