Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
My lacie external drive cannot be located even though it is connected to my macbook. i can connect it to a PC with no problem but all tiff files are mac based so cannot open them in the PC. What should I do? thanks in advance
  • elainek_975 May 13, 2009
    hello - i am unable to access my lacie drive with my mac book pro. it's a firewire lacie drive. what can i do to retrieve my information?
    President:
  • 272 Answers
Hook your drive back to your PC. Right click on it and check 'properties'. In the box that pops up if it says file system NFTS you are out of luck as that is a non mac compatable file system. If it says FAT32 it should be working on your Mac. If it says NFTS you'll need to transfer the files onto the PC reformat the drive using the LaCie software to FAT32 (the only file system that both Mac and PC can use) then transfer the files back to the external drive. Reformatting erases everything on the drive so don't forget to transfer the files first! I can place Tiff files into Adobe products on my PC so I'm not sure what you mean by Mac format tiff???
Posted on May 10, 2009
  • rjbeg123 May 11, 2009
    If my solution helped you please rate me!
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Can a lacie rugged external hard drive be connect to a macbook -not macbook pro?
Yes - If the unit is USB it will work with any computer that has a USB port - if hooked up to any Mac though it normally will be formatted for use only with other Mac's. You can usually specify what type of filesystem you want to use when you have it hooked up.
Mar 16, 2011 | LaCie Rugged All-Terrain (301017) Hard...
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Can't open folders in same window
it is a trojan download trojan remover and also run malawarebytes they are free and safe to use
May 07, 2009 | LaCie 320GB P3 Firewire External FireWire...
Sharing Lacie with MacBook & PC
Unless you use a specific software package to resize the existing partition (partition magic et al), the original partion and contents are effectivly erased... they can be recovered using disk recovery software in most cases though
If you still have the source files and both systems can see and write to their respective partition of the Ext HDD, then the easiest way to move forward is to just copy your files back onto the assigned partition.
Jul 14, 2008 | LaCie (301146U) 320 GB FireWire 400...
Firewire problem I think - I have a Sony Vaio laptop, the firewire port is 4 pin, it is connected to a LaCie CD Burner via 6 pin and the burner is daisy chained to a AcomData external hard drive via 6 pin....
If the hub has an external power supply it migh do the trick. That way you can have a backup port if needed.
Make sure the hard drive isn't connected to the hub. Sometime windows doesn't see it when its connected to a hub.
Jul 14, 2008 | Computers & Internet
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB not showing on MacBook Pro
The first thing that I would do is try connecting the drive to different USB Ports. If that does not work see if there is any software that came with the drive or that you can download from the internet that you might need to get the drive working. Next I would connect it to a different computer to see if it works that way. If it works when connected to a different computer I would at least get the files on to that computer and transfer them to the computer that you need them on using a network connection, a CD/DVD, or a USB thumb drive.
Nov 07, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
468 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
