Question about Garden
My tractor cuts out and dies, then with a recharge, it runs.
The tractor is a 18hp twin II. It starts and runs, then cuts out and dies. If it sits awhile with the battery charging, it runs again for several minutes, then cuts out and dies. Is this an electrical problem? What would cause that? Model number of motor is 422707, type 1229 02, code 9302255B
  • rickapollo May 10, 2009
    Thanks, rjberg. I'll change the oil this week, although I don't have a low oil pressure cutoff switch. It's air cooled, but Ill clean the venting on the head as well.
    rickapollo
    President:
  • 272 Answers
Not likely, if the battery is any good you should get several hours of run time before it dies. More likely low oil pressure cut off switch, check level or change oil if it's been awile. Or possibly an overheat cuttoff swith, check airlow and coolant if it has a radiator.
Posted on May 10, 2009
My cub cadet wont restart after it gets hot
what engine do you have and how long has it been doing it for, try a new plug at first.
Jan 10, 2013 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
Briggs and stratton engine runs rough, Twin II 18HP
check carburetor and ad carb leaner and gas treatment has to be on full.
Sep 09, 2012 | Measuring Tools & Sensors
Engine dies when hot fuel not pumped round the system kohler 18hp
If the engine has a black pump on the side of the engine it may be faulty, there is a diaphram inside, but the pump is non servicable, it takes a pulse from the cylinder head or rocker box, this pulses the diaphram, which then pumps the fuel, as there is no gravity feed from the tank, it requires the pump to fill the carb.
May 19, 2012 | Garden
Gravely model 992005 runs fine untill moving
sounds like there is still a passage that is still dirty in the carb or the float level is off
Apr 22, 2012 | kawasaki Garden
After running 2 minutes tractor cuts off
The fuel not going to carb.
Mar 03, 2012 | Ford Garden
I have an 18hp 42inch cut Sears Craftsman, it will
You might want to checked your fuel line coming from the tank,sometime it will collaspe inside the line and not allow enough gas to get to the engine.
May 15, 2010 | Garden
B&S Intek OHV 18hp muffler glows red hot
sounds like its running too rich on fuel. try turning the fuel mixture screw in 1/4 turn at a time til it starts to stall then turn out 1/4 turn or 2 and see if that helps.Maybe when you used the air it turned this screw???
Nov 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Need older 18hp b@s hrizontol shaft motor
If you don't run it any longer you make be able to replace the connecting rods and clean the aluminum from the rods off crankshaft with a very fine emery cloth. A clyliner hone and a new set of rings would also be needed.providing the cylinders arent scored. A gasket set and parts would probably set you back about 100 to 150.
Jul 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
It won't start with key; new fuse and new selinode and the starter is fine craftsman riding lawnmower 42 in cut and 18hp
It may possibly be the seat switch. There is a little button under your seat, it is a safety mechanism. It's so the mower won't start without someone actually sitting on it, it will also shut off atuomatically if you fall off. If your good at wiring, and splicing, you can cut the wires and splice them together, and see if it starts. Hope this helps a bit.
Apr 29, 2009 | Craftsman Garden
Garden Logo
327 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
