Question about Razor MX500 Dirt Rocket
Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
My son's "new" Razor MX500 Dirt Rocket is having a problem with the drive sprocket. The motor runs, the chain goes, the rear sprocket turns, but the rear wheel won't "grab." The sprocket is not catching to turn the wheel. I have taken the rear wheel off and removed the sprocket and am down to the bearing, but I don't know how exactly to pop the housing open without breaking something. Any suggestions on how to open the housing the holds the "catching" mechanism, and when I am there, what to do to fix the problem? Thanks, Brad
  • buckeyephill May 13, 2009
    khairun200 - do you have nothing better to do than leave useless"solutions?" What a waste of time!
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
Posted on Nov 03, 2010
  • gilmary Nov 13, 2010
    I am working the same problem, the freewheel isn't catching and driving the rear wheel. I have it all apart and am trying to take apart the freewheel to get to the bearings. I am trying to figure out how not to break, bend or destroy the freewheel. I presume fixing the bearings or pawl springs with fix the problem. Did you finish your video on how to fix this?
I had the same problem and just welded the gear so it wont slip.
works great!!
Posted on Jul 03, 2009
  • james o Nov 14, 2011
    t'hat's awesome...i thought of that..f@#king razor and it's cheap parts
I bought a razor mx500 from a private party who got it as gift for his son, from a friend and it was brand new in a box, after assembling the whole thing, He noticed the back wheel was not spinning and feeling embarrassed to ask to return it, he rather sold it. I notice the back wheel was not engaging and took it to a welder and pay 4 bucks for 2 points of welding from the rear sprocket to the wheel and problem was solved.
Try it, is the cheapest solution.
Posted on Oct 10, 2011
    Problem Solver:
  • 7 Answers
Losen the screw
Posted on May 11, 2009
Razor's own web site says to fix this problem with WD-40. Here is the link: http://razor.custhelp.com/ci/fattach/get/14304/1268434064/redirect/1
So is Razor support wrong? Or has this changed?
Posted on Jul 15, 2012
  • 2 more comments
  • Darren Vallaire Jul 15, 2012
    Razor's own web site says to fix this problem with WD-40. Here is the link: http://razor.custhelp.com/ci/fattach/get...
  • Darren Vallaire Jul 16, 2012
    Since I was not up for trying to take the flywheel apart or fabricate a spring (was just going to pay the $50 for a new rear wheel), I tried what Razor said on their web site (see link above) with the WD-40. It took a bit of spraying and running the throttle. A good 2 or 3 minutes of both, but low and behold it worked. The bike is working again. Anybody's guess how long it will last.
  • Darren Vallaire Sep 13, 2012
    Ok, it's been 2 months and still going strong just by spraying WD-40 as stated on the Razor web site.
    Problem Solver:
  • 8 Answers
It is the rear freewheel assembly causing the problem. if is fixable, but you have to be good with tools, the bicycle shop and the electric bike shop both said they couldn't fix it, but is is doable. 1. you need a special bmx tool that fits that back wheel, your local bike shop should have it in stock. 2. you need to remove the freewheel sprocket and disgard it along with the the bearings (make sure to unscrew the razor chain sprocket from the freewheel assembly and secure it for reuse). 3. either purchase a new freewheel sprocket for bmx wheel or remove one from a old bike (again you will a special tool for that). 4. screw the razor chair sprocket onto the new BMX sprocket (it goes on with the same 4 original screws, right over the sprockets. 5. Screw the freewheel back onto the rim now. tada its fixed.
Posted on Sep 13, 2012
I know this is a bit odd but i have a 100cc dirtbike and the back wheel does the same thing, the sprocket will turn but the wheel will not move... i need help becuase its gonna cost a bunch to fix it. is it possible to weld or what did you do to your back rim?
Posted on Oct 03, 2009
  • bigalgoodwin Nov 03, 2010
    I took my son's MX500 rear assembly to a bike shop. They removed the flywheel and took it apart. My son had sprayed WD40 around the back axle (bad - WD40 is a degreaser and bearings are packed in grease). Without grease, they were flying all over the place and caused major damage. The spring Razor provides is cheap and designed to fail. The bike mechanic had to fabricate a new one. Then he put the 3 pawls back in place, re-packed the bearings in new grease, and re-attached the flywheel to the wheel (it screws on and off). I'm going to post a YouTube video of the repair later. I put the wheel back on this morning and took it for a test drive. It ran fine. Besides having a very cheap spring that is designed to break easily, Razor did not use enough bearings. This also aids in rear wheel assembly failure. From the factory, there were 12 bearings missing. In short, buyer beware when purchasing any Razor product. Don't say I didn't warn you.
Engine runs but wheels do not move
This could be a few things:
1) Your clutch plates may have worn out so that even when the bike is in gear, it will just rev, but no power will be transmitted to the drive shaft (smaller front chain sprocket is the driving gear, larger rear sprocket on the back wheel is the driven gear)
2) The front chain drive sprocket has come off under the cover on the motor - if the chain is really slack, have a look.
3) The front chain drive sprocket SHAFT has sheared. (basically, meaning that the shaft has broken into two parts as it couldn't handle the drive power (torque) being delivered through it to the chain drive) With the motor on, listen for grinding noises internally
when you rev, from the vicinity of the front chain drive cover. If its rough and grindy, the shaft may be sheared. Then with the motor off, take the cover off and leverage the small chain drive sprocket away from the motor with a screwdriver, and see if the shaft can just be pulled out of its sealed opening. Unfortunately with these bikes, the metals used in drive shafts and motors are not always heat-treated or hardened to the standard they should be, so shearing and premature failure can happen.
4) The gearbox or something in it has blown, unfortunately for the same reason above, quality related.
Its fair to say that these great little bikes are here for a good time, but not for a long time.
Apr 11, 2014 | Razor MX350 DIRT ROCKET - BLUE
Chain will not stay on
Jessica:
First, check the chain and sprockets. Check the two chain sprockets for worn or bent teeth. If either of the sprockets is damaged, replace them. If the sprockets are OK, Check the chain for any damage If the chain is damaged, replace it. You are checking the chain for kinks, stiff links, damage to the link side connectors, and checking that the chain is not bent (side to side) Check to see If the chain is loose. If it is, you'll need to loosen the rear axle nuts and pull the rear tire backwards to tighten the chain, then tighten the rear axle nuts. *Make sure that the rear sprocket lines up with the front sprocket*. Just lay a straight edge along the two sprockets, ( A yardstick will do), and make sure that the sprockets touch the yardstick along the whole length of the sprockets. If the rear sprocket is cocked (not lined up with the front sprocket) loosen the axle nuts again and push on one side of the rear tire or the other side until the sprockets line up.
When you are finished tightening the rear axle nuts, pull up on the chain between the sprockets... the chain should not move up or down more than 1/8 of an inch. The chain will stretch over time, and you need to check the chain for looseness before riding.
Happy and safe riding!
Feb 01, 2014 | Razor MX500 Dirt Rocket
There seems to be a loud clicking noise coming from the bike when my child drives it. Any ideas what is causing this?
Does the clicking rate vary with wheel speed? Check the chain tensioner and the freewheel. If your freewheel only has 4 notches in it for the removal tool, it's an older one. They can get noisy before they go bad. If it has 8 notches it's a newer one, they beefed it up. Take the chain off the motor sprocket and turn the shaft. If it makes noise and wont turn smoothly, your motors bad. Check the chain for stiff links, and look for any broken plastic parts or loose bolts or screws. Check the nut on the shock and tighten that if it's loose.
Aug 07, 2013 | Razor MX500 Dirt Rocket
Chain is turning but the rear wheel is not moving
What??? RLtoFixYa doesn't know what they are talking about. Your problem is a faulty/broke "one way roller clutch" which is threaded onto the rear wheel. I've already replaced 2 on my son's MX500.....
May 25, 2011 | Razor MX500 Dirt Rocket
Rear wheel sprocket turns with chain, but doesn't "grab" to turn the back wheel. I have removed the wheel and taken the sprocket off the wheel, but I don't know exactly how pop the housing open...
BEST SOLUTION GO TO A GOODWILL MOST OF THE TIME THEY HAVE-
BIKES FROM $10.00 TO $40.00 AND YOU LOOK FOR A BIKE
THAT HAS A GOOD BACK WHEEL AND YOU'LL HAVE EXTRA
PARTS HERE IS A LIST OF PLACES GOODWILL&THRIFT STORE&
SWOPMEET THAT HOW I FIX MY BIKES..
HAPPY HUNTING.
D,R,CLAUDIO
Jan 19, 2018 | Razor MX500 Dirt Rocket
The chain on the MX500 dirt bike is slipping over the sproket on the back wheel. I've read the posts where the sproket turns but the wheel does not, that is not my issue. I'm thinking I just need to...
Is there a chain adjustment on this bike? It must be very loose to slip over the sprocket. See if there are two bolts that act as jacks to move the rear wheel back away from the drive sprocket. Loosen the locking nuts on each bolt, and tighten both equally until there is only 1/2 inch of play in the middle of the chain, then repost.
Gary
Dec 22, 2010 | Razor MX500 Dirt Rocket
Early model Razor MX-500. Replaced motor, control module to 5 wire, and throttle. Still, clicking inside controller but will not send power to motor. What's up?
the back wheel won't move it try to move but it won't it's making a loud noise.every time you give it gas.what could that be...
Dec 26, 2009 | Razor MX500 Dirt Rocket
How do you get the tire of the rear rim of the razor mx500 electric dirt bike???
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
Jun 09, 2009 | Razor MX500 Dirt Rocket
Getting Chain back on MX500
I can do it for you because I had to change my rear tire as well and I have done it before and I will do it for you free of charge but I live in Bronx, New York and I have no idea where you live LoL... If anything my E Mail is phillyphiljesus@yahoo.com
May 09, 2009 | Razor MX500 Dirt Rocket
Razor MX500 Dirt Rocket Logo
6,245 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
