Question about Hitachi P42H401 42 in. Plasma HDTV
P42H401 Poor Power Supply?
The 42" TV will not power on. Opened up the back and checked for any obvious problems, but I don't see any scorched or burned parts. Seems to be the power supply stage. I can hear a relay or switch flip shortly after turning the TV on. I then hear what I can best describe as a chirping noise coming from a large transformer on the power supply board (at least that is where I believe the sound is coming from).
The transformer is part # 1JE0081
If someone can supply the service manual I could measure the voltages that go to the digital section. I'm guessing that this transformer switches the 120V AC to a lower voltage before being rectified and then regulated via the IC regulators on the power stage.
Can anyone provide some assistance? or perhaps the service manual for this TV so I can work on it? Thanks
SOURCE: intermitten problem with hitachi plasma on power up
well aparently all you do is fish for customers to buy into your sevice!
I DIDNT GET ANY HELP FROM YOU GUYS, TAKE YOUR "FREE" TECH SUPPORT AND SHOVE IT UP YOUR ***!!!!!!!
Posted on Nov 13, 2009
  • 579 Answers
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
ilragatzzo78
  • 241 Answers
SOURCE: ESA 42" plasma tv not turning on
you have a bad power supply, is shorted so you need to replace it , do not turn it on or you will burn some other items and then the cost to fix it will increase drastically.
Posted on May 29, 2008
SOURCE: 55HDS69 Power Supply problem
I have found that the power supply is usually good, it's the other boards that tell it to shut down within a second. There are input called Vsego and VSago that tell the power supply to stay on.
Posted on Mar 09, 2009
  • 44 Answers
SOURCE: gateway 42 inch plasma p42m303 6 blinks on power supply
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
Replace procedure for power supply capacitor in P42H401 Plasma TV
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Electro help
Jan 12, 2014 | Hitachi P42H401 42 in. Plasma HDTV
Volume works but picture wont show
It is likely your TV has power supply trouble.
Nov 08, 2013 | Hitachi P42H401 42 in. Plasma HDTV
No power on Hatchi p42h401 allready replaced power supply
IF you got a good board and a lot of replacement boards aren't good the only other thing that would make the set dead is if you have a bad main board, if your able to pull the back off and test the either 3.5 or 5 volt standby voltage if its ok then look at the PSON voltage, it should be at a half volt and go to about 3.5 when the power button is pushed..if you don't have standby you have a bad power board yet, if you have standby but no PSON the main board is bad, if you have PSON its back to the PS as being bad...Good luck!!
Feb 01, 2018 | Hitachi P42H401 42 in. Plasma HDTV
My dynex tv wont turn on! the strom knocked out our power, now the power is back on the tv wont turn on from remote or tv power button.
Lightning is a weird beast, and can do strange things to a TV. Sounds like the set took a hit. If there is a fuse then check it on a volt-ohm meter for continuity while it is out of the circuit, and if it is an open circuit, replace it. If there is a circuit breaker, then reset it. If these don't work, look for obvious scorching on the circuit board (assuming you know how to avoid electricution, otherwise do not touch). Lightening can literally jump around on a circuit board, so there is no way to know what part of the set was effected by the strike - the lightening will not always burn out the first circuit it touches, but will burn out something further into the circuit. The most obvious place to look is around the transformer and rectifier circuits. If a capacitor was hit, it may be swolen or discolored; resistors will scorch, and the worst thing is that transistors and IC's often show no damage - in fact, any part might be burned out and not show visible signs. If nothing is obvious (like scorch marks) and the fusing is intact, there are too many possibilities to begin listing them all. The fact that it won't turn on at all sounds like it is probably a power circuit, but, not necessarily. FYI turning a set off during a lightning storm does not protect it, you have to unplug the AC power cord and the line that feeds the signal into the set. Even circuit protection devices (lightning arrestors) may not protect against a close strike. Maybe the techs at Best Buy can supply more suggestions (Dynex is their brand).
Aug 29, 2011 | Dynex DX-L42-10A 42 in. LCD TV
Switches on then off after about 20mins
hi there,
you have a bad joint, may be on the power supply you have to check the 5v,3.3v
chears
May 25, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Hitachi 42plasm tv
take it back to the store, make sure the power cod is in all the way and you dont have it on a switched outlet, see if you can see any cracks or if the box was damaged/
Dec 08, 2007 | Hitachi P42H401 42 in. Plasma HDTV
Hitachi P42H401 42 in. Plasma HDTV Logo
172 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
