Question about Garden
JD Lawn Tractor L130. will not start
I have a JD Lawn Tractor L130. I ran yesterday and it ran and mowed great. After shutting it down and it just sitting a short time I went to run it again and it would not start. Yes it is full of gas. Went to try again today and it will still turn over but will not start. What should I try now?
    President:
  • 272 Answers
They have an auto shutoff for low oil, start there check your fluids. If Ok check for spark. Try full throttle choke off in case it might be flooded. See if any of that works and let me know.
Posted on May 10, 2009
  • 122 Answers
Have you checked for spark? although odd maybe a coil went out on you even after just shutting it off.
Check under your seat there is a switch make sure it is pluged in to the wire.if its not pluged up the engine will not start
Posted on Feb 27, 2013
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Apr 16, 2010 | Garden
I have an L130 lawn tractor. The blades turn off
Look for a loose or broken tensioner spring, also check the belt condition
Sep 15, 2009 | Garden
Have a JD STX 38. Put an ign light on it, no
have same tractor same problem mine was coil ran but when i shut off after mowing wouldnt start changed coil no problem since
Aug 17, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
429 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
