Question about Dryers
Kenmore series 80 gas dryer not heating
Hi. I reset fuse, cleaned hose (which did have a lot of lint... even though I clean lint tray after every cycle).. but still no heat. I have no idea how to take off the back of the dryer or what to look for. Can you help? Thanks! Hi Illeagle,
I have been reading this post and it has been quite helpful. I have a Kenmore series 80 dryer model number 11074892401. My problem is no heat but hte drum and blower are working. The ignitor is not fheating up. I have checked all fuses and thermostats and have no open connections. I have discovered that there is no voltage being delivered to the ignitor. All the blogd I have read say to check the timer contacts that feed the ignitor but can read how to do this. Can you help? Do i need a new timer switch entirely or is there a way to isolate the reason why I get no power to the ignitor?
  • dotsonian May 11, 2009
    Thanks for the replies. In the link by themobilian it had a helpful tip for a beginner in checking continuity. I had not been uplugging the connector wires from the components I was Ohms checking. I had been unplugging the dryer though. Once I did this I was able to see that the thermal fuse was open. Thanks for the link. It's a good reminder to "dumb down" the replies on these blogs where lots of novices are posting.
    sorry don't know what "fixya" is but you can have one
    President:
  • 1,136 Answers
Hi, If you have a gas dryer with no heat, here is what you can look for. You need to remove the front bottom panel by putting a flat screwdriver in the crease right below the door. There should be two clips that will release the panel. Then turn the dryer on and see if the ignitor comes on (it will glow bright orange). If it does not glow, there is a bad fuse in the dryer or a thermostat bad. You can check those parts by taking a contnuity test on them. NOTE: Be sure and unplug the dryer!!
If the ignitor does glow, you will probably need to change the coils on the gas valve.
Please let me know if this helps you at all.
Vic
Posted on May 10, 2009
  • Dryers Master
  • 8,220 Answers
Replace this fuse
Check THIS out
  • Dan Webster
    Dan Webster May 11, 2009
    Hell if ye seen I had a good tip then why didn't i get a FIXYA dangit. Shoot fire and save matches.
    :D
  • Dan Webster
    A fixya is a rating of 4, your rating to me was helpful which is a 3. I thank you.
My kenmore 5200 series gas dryer won't heat. My
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Kenmore Dryers
Maytag Peforma Series MGD5740TQO Runs - does not heat Cleaned all lint from dryer and hoses
heatman101
Aug 16, 2011 | Dryers
Dryer won't heat up and its not the element or thermal fuse....lint trap and hose are clean, any suggestions?
heatman101\][
Mar 28, 2011 | Kenmore 63942 Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
MY KENMORE 80 SERIES DRYER ISN'T HEATING
remove the entire exhaust vent and clean it thoroughly. Any build up of lint inside of it will cause the moister sensor in the dryer to shut down the burner or grid which ever you have, gas or electric
After cleaning it and it still does not work correctly the sensor is at fault and needs to be replaced
May 17, 2010 | Dryers
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Hello I have a Kenmore gas dryer model# 1107282210 and the dyer seems to give off a little heat but then I it will stop giving of heat and the clothes will take very long time to dry. Now I cleaned the...
HI, Check the following to address this issue further.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task. The blower housing should be disassembled, and cleaned in this case.
2. Thermostat(Secondary Cause)- Highly unlikely in your case, but possible
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 17, 2009 | Kenmore 73952 Gas Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
336 people viewed this question
Top Dryers Experts
