Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
6.75 briggs and stratton carb problem
Engine ran out of gas when filled it with gas the next day engine would not start i replaced the spark plug and air filter and cleaned the carb. engine now starts on first pull but shuts down to me it seems to be losing itsprime please help
  • 122 Answers
Might have picked up some sedements from being low on gas. check your diaphrams in the card a small hole or even dirt can stop it up
Posted on May 10, 2009
Craftsman gold 6.0 hp. walk behind lawnmower wont start
Back to basics, is the fuel in the tank good?( fill with fresh fuel ) does it have a spark at the plug?(remove the plug, earth against the cylinder, is there a spark,if not, replace the spark plug and try again ) does the plug wet with fue lafter pulling?( clean/service carb ) is the spark occuring in the correct place ( flywheel key sheard ) has the engine got good compression?
Aug 19, 2013 | Briggs & Stratton Briggs Stratton...
I have a briggs and stratton 13.5 hp power engine that wont start. The engine is almost new, oil level is good and when I remove the spark plug cap and dold it near the top of the plug and pull start it I...
there may be safety switches, but if you are getting a spark, that is not the problem. After you cranked with no start, is the spark plug wet with gas? can you smell gas in the cylinder after pulling the plug? It could be that your carb float/needle valve are stuck closed. Try lightly tapping the side or the carb.
Jun 08, 2017 | Briggs & Stratton Briggs Stratton Intek V...
Hi I have a 22 hp briggs in a husqvarna rider. Started running a little rough at season end last year. This year it started, but ran only about 2-3 min, then would not start at all, put in new plugs (old...
This a common problem after they have set up over the winter. Water has probably condensated in your gas tank and now it is in the gas line. The tank should be drained of old gas and the gas line to the carb should be removed from the tank and blown out with compressed air to remove all old gas/ water. Attach the gas line back to the tank and refill the tank with new fuel. This should take care of the problem. To avoid this next time, just fill your gas tank to the top at the end of the season and leave it full through the winter.
Mar 28, 2011 | Briggs & Stratton Briggs Stratton Intek V...
26 hp briggs it is firing and full of fresh gas but wont start.
Well you didn't indicate what its mounted on but the basics are: spark and fuel. Pull a spark plug and make sure you get spark. If you do then it must be fuel. You can try a shot of starting fluid (small amont) into the carb, if it runs on that you know you have a fuel problem. Be sure the carb is getting fuel from the tank. Clean the carb. Maybe a carb kit. With today's fuel, you must take care of your fuel system. Use Sta-bil year round. Fuel can go bad in 60 days.
Jul 18, 2010 | Briggs & Stratton Briggs Stratton Intek V...
19 hp Murray garden tractor won't run
no sounds like your carb needs a real good babtising! good look!
May 19, 2010 | Briggs & Stratton Garden
The engine starts but run for 10 sec. when add gas to carb.
with it backfiring i would guess the valves may need adjusting and if that does not help clean the carburator.
May 03, 2010 | Briggs Stratton 020273 Elite Series...
Engine will not start. there is oil in the air
I would start by draining the old gas out of the tank and filling with fresh gas. Replace the spark plug.
Jul 12, 2009 | Briggs & Stratton Tools & Hardware -...
Can't start brisggs & Stratton 21in mower. I
Get some GUMOUT carburator cleaner GAS ADDITIVE. Put about 1/2 TEASPOON in the gas tank and about 1 tablespoon per gallon into your spare gas. The float pin is probably sticking from winter non-use. This will free it ip.
You can also remove the bowl from the carburator and spray everything to immediately dissolve the varnish. Be careful not to lose the pin spring.
Jun 13, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
288 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
