Question about American Standard 1340M.105.002 Polished Chrome Pillar Tap Metering Faucet
Just installed a kitchen faucet and now it leaks when on at the b
When turned on it leaks at the base of faucet, where the facucet and countertop connect. There is no water flowing in that area. Any ideas
    New Friend:
  • 92 Answers
Sounds like you may have clogged the little screens at end of spout try unscrewing and see what happens if not you may be suffering from the returned part open box syndrome
Posted on May 11, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Leaky faucet
    This is generally due to a loose or faulty cartridge. To fix:
    1. Turn off water supply valves under sink.
    2. Block the sink drain to avoid losing small parts.
    3. Remove faucet handle. It is attached by a set screw, an odd size (I actually used a T9 torx screwdriver successfully, even though the set screw is hex head, since I did not have a matching allen key). The set screw is quite far into the handle, ~3cm, through a hole in the bottom of the handle. Depending on your countertop layout, you may have to actually remove the entire faucet from the countertop in order to get access to it, in which case follow the appropriate parts of your faucet installation directions in reverse.
    4. Remove dome. It will come off with a gentle turn/pull.
    5. Check the tightness of the exposed large hex nut. This is the piece that holds the cartridge in place. If you are lucky, it is just loose, and that's your problem; otherwise you will need a new cartridge.
    6. Unscrew that nut, remove. Pull out the cartridge.
    7. Replacement cartridges may be found at your local Moen dealer, or may be ordered directly from Moen +1-800-Buy-Moen. Parts are free due to the lifetime warranty. Part #1255 includes the cartridge, cartridge nut, and set screw. The nut must be changed with the cartridge (presumably due to its wear characteristics).
    To reassemble:
    8. If you have it, place a very small amount of plumber's silicone lubricant on the back of the cartridge, on the rubber seals around the three holes.
    9. Assemble in reverse order of disassembly. The cartridge only goes in one way, due to three guiding channels on its perimeter.
    Enjoy!
    Oct 08, 2012 | Moen 87877SRS Haysfield Spot Resist One -...
    How to tighten mown faucet. Wobbles at base on countertop
    There are screws that come up through the bottom. You may have to remove the faucet to tighten it. While you have it out, throw it away and buy a new one.
    Feb 04, 2018 | Moen 7840 Camerist Single-Handle Kitchen...
    Replaced back yard facucet now water wont turn on
    make sure you have water coming to the tap, if so then you need to take the tap apart theres an inside seat there that you can adjust for more or less flow
    Jul 29, 2011 | B&K BK Mueller 122048RP Single Lev Kitchen...
    When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
    Hi seawitch678,
    If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
    Hope this helps. If it does, I'd appreciate your vote. Thanks,
    Handie Andie
    Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
    Water leaking from the faucet onto the countertop.
    http://docs.homeclick.com/PE-Links/Rohl/Rohl-A3608-specs.pdf
    Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
    It has a breakdown of faucet internal parts.
    Jun 04, 2010 | Rohl A3608LMPN Single Lever Country...
    Kitchen spout leaks
    Hi buffy9,
    I'm Harvet the Master Plumber.
    Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
    Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
    Thank you,
    Harvey your Master Plumber
    Oct 16, 2008 | Plumbing
    American Standard 1340M.105.002 Polished Chrome Pillar Tap Metering Faucet Logo
    95 people viewed this question
    Top American Standard Plumbing Experts
    john h
    Steve Wood Plumbing...
    Level 1 Expert
    Mike
    Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
