Question about Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven
My oven doesn't work but the broil and top section does. I remove the cover from the oven burner section and saw a glow.
    President:
  • 1,136 Answers
Hi, Sounds like it might be the element. If you shut off the power to the oven and rmove the element some that you can test it. Check and see if the element has any bubbles formed on it like it has burned through. If it lookes ok, test continuity to make sure that it has not breaks in it. If I can help further, please let me know.
Thanks,Vic
Posted on May 11, 2009
Hello, My Thermador GSC30CVwc1 broiler does not function. How can one troubleshhot this problem? Thank You
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Oven Won Turn on
Mar 11, 2014 | Thermador Ovens
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Nov 15, 2011 | Whirlpool Ovens
I have kenmore gas oven ignitor glows but will not light
Hello there:
It doesn't bake dot_lineone.gif Bake igniter
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
If you are certain the igniter is ok, it might be a good idea to call a professional appliance technician.
Need a new oven igniter? Click here for most common oven igniters or enter your oven model number in our PART SEARCH. ^ top clear.gif It doesn't broil dot_lineone.gif Broil igniter
When the broil igniter becomes weak or burns out, your oven would not broil. The broil igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the broil igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#ixzz1CgFQ7lBJ
Feb 01, 2011 | Kenmore 33169 Gas Single Oven
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
My oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Feb 05, 2010 | Frigidaire FEB27S5A Electric Single Oven
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
    Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
    Apr 25, 2009 | Ovens
    TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
    Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
    Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Gas stove
    The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
    Sep 04, 2008 | GE JGRP17 Gas Single Oven
    First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
    Nov 11, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
    Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Logo
    551 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
