Why do channels show up as 10-1, 10-2, 10-3 etc...Instead of just the 10, 11, 12, etc...
  • 122 Answers
I noticed with the new digital you can have more then one station now, on the same channel like a radio for instance
Posted on May 10, 2009
My son bought this TV and had it hooked up to a cable connection with an HDMI cable and it worked fine. He gave the TV to me and I hooked it up to a basic cable connection with no cable box. It does not...
If your TV has an On-screen Menu you should be able to access your Tuner controls. Run your auto channel scan and you should pick up your "regular channels". You may be able to de-select the odd channels and show only the ones you want to use.
Oct 03, 2011 | Westinghouse LTV32W6HD 32 in. LCD...
What is the power output in a power amp and is it expensive
the output transistors are 5 to 10 bucks each for most.there are 2 or 4 on each channel,depending on brand .some high end amps have 10 transistors on each channel.mosfets are a different story as they run 20 to 50 bucks each and there is 2 or 4 on each channel.some amps use a big IC instead of transistors.those have 16 to 24 pins and are easy to change. Those IC are 25 to 75 for a stereo one like stk4141 etc.since most yamaha amps are dc coupled,when the output transistors go,they take out the driver transistors as well.If you replace the outputs and the drive transistors are shorted,they will blow the outputs again.
Apr 14, 2010 | Yamaha P3500S Amplifier
When my Tivo stops recording a show on, say, channel 54, instead of staying on channel 54 it switches to channel 5. In other words, it only gets ''part'' pf the channel number. This happens with other...
The end of the IR Cable that attaches to your cable box may have to be repositioned.
Try moving it a small distance (you are already close or you wouln't be receiving ANY channel changing info. from it) and see if that helps.
Sep 12, 2009 | Tivo Series2 TCD649080 Video Recorder
I upgraded my wii to 4.0 and installed the homebrew channel.Everything seemed to work great,so I tried to play guitar hero 3 the game shows up in disc channel but when you click start the screen goes black...
You might want to try a Loader instead of the Wii's disc channel. Are you playing original games or backups? You might have broke the Homebrew channel with the 4.0 upgrade. Check out this Wii homebrew set of tutorials to see if it'll help
http://www.wiilovemario.com/The-most-up-to-date-Wii-Homebrew-and-Backup-tutorials-known-to-mankind
Jul 16, 2009 | Nintendo Wii Console
My th-79a shows channel numbers only
RTFM Page 29
Press [BAND] + POWER ON to toggle Channel Display
Gerard - PE1OUD
Mar 04, 2009 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Lost remote mrd 310
most universals will use this method.
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 29, 2008 | Philips Magnavox Learning Universal Remote
Skifi xm
click on the display button until it shows the channel name
Aug 19, 2008 | Delphi SKYFi3 XM Radio Receiver
PROGRAMMING
You have to get into your database programing "Feat, #, * " Says enter password, Default is 00000000. Enter into "Staion" then where it says "Show sta" enter 11,12 13 etc. "show" scrole to "CO Line Ring Assignment" Enter "Both" on each station you want to ring. Station #10 is the only default station that will ring without reprogaming the other ones to ring along with it. Hope this helps.
Oct 10, 2007 | Vodavi Starplus DHS 7312 Enhanced Phone
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
